2008 Thruxton Drain Plug: - Triumph Forum: Triumph Rat Motorcycle Forums
Old 12-02-2012, 09:28 AM   #1 (permalink)
Main Motorcycle: 1986 BMW R80RT
Other Motorcycle: 2008 Thruxton
Could someone tell me the measurements for a Thruxton drain plug?
Thank You
KThunder is offline   Reply With Quote
Old 12-02-2012, 09:37 AM   #2 (permalink)
Main Motorcycle: Bonneville America
grzegorz's Avatar
M14x1.5 pitch ,flanged
pictures
grzegorz is offline   Reply With Quote
Old 12-03-2012, 01:32 AM   #3 (permalink)
That the same as M14 X 1.5 X 12?
Old 12-03-2012, 03:37 AM   #4 (permalink)
Legend
Forchetto's Avatar
M14 x 1.5 x 16, 16mm being the length.
Old 12-03-2012, 05:51 PM   #5 (permalink)
Oh ok. The reason for my reply was one of those expensive magnetic drain plug companies quoted me an measurement of M14 x 1.5 x 12. I am guessing either the 12mm or 16mm would be fine?
Old 12-03-2012, 06:31 PM   #6 (permalink)
Main Motorcycle: 2009 Bonnie EFI
TX1911fan's Avatar
With the magnet on the end, maybe you need the bolt to be a little shorter?
TX1911fan is offline   Reply With Quote
Old 12-03-2012, 10:30 PM   #7 (permalink)
Perhaps as I was thinking the same because the the magnet protrudes slightly making up the difference. Well, just curious.
Thanks for all your imput.
Old 12-03-2012, 11:57 PM   #8 (permalink)
Legend
Forchetto's Avatar
The 16mm magnetic plugs shown on this thread fit fine. Plenty of clearance where the plug screws in:
http://www.triumphrat.net/twins-tech...oil-plugs.html
Oil Drain Plug?? robertrichhart Thunderbird Twin - Technical Talk 13 09-08-2009 10:09 AM
Oil Drain Plug Londonspride Twins Talk 4 09-09-2005 09:25 AM
Oil Drain Plug Londonspride Twins Talk 2 09-08-2005 11:29 PM
Oil Drain Plug Londonspride Twins Talk 0 09-08-2005 08:41 PM
oil drain plug jeffro232 Speed Triple Forum 5 07-08-2005 11:05 AM
