Single Seat & Rack Kit w/Cowl? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-30-2012, 09:00 PM   #1 (permalink)
Main Motorcycle: '11 Speed Triple
Moogs's Avatar
Other Motorcycle: '13 Mag Wheel Bonnie
Can I put a cowl on this if I remove the rack kit? I find the rack kit good for touring but otherwise would prefer a cowl when not in use. If I ever go two up I'd put the plank back on.
http://www.pure-triumph.com/products/443
I hear these are really comfortable. Is this referred to the "solo seat" or is this it?
Whomever said all good things in moderation certainly never rode a bad ass Bonneville
Moogs is offline   Reply With Quote
Old 11-30-2012, 09:04 PM   #2 (permalink)
Main Motorcycle: 08 Bonneville Black
ruger's Avatar
Yes sir. i did it with mine. I used short bolts to keep the pieces together since the rack screws also hold the plastic trim piece to the seat pan. I have the sixty8 cowl. Not sure if it's the same cowl as one from the Thrux but someone can probably chime in and tell us.
Ruger
Long may you run-Neil Young
ARK/Dominators/Works/Progressive/EBC rotor/Rocket III master cyl/Pazzos/170 rear/TPUSA tach kit/520 kit,19T/Denalis/Bashplate/DEcosse MOSFET upgrade/More crud/Ruger's Garage
ruger is offline   Reply With Quote
Old 11-30-2012, 09:06 PM   #3 (permalink)
Main Motorcycle: duh
bheezy27403's Avatar
Other Motorcycle: old mini bike
Someone will chime in with the answer. But, if memory serves, I have read a post somewhere and this has been done. And yes, that is a single seat.
bheezy27403 is offline   Reply With Quote
Old 11-30-2012, 09:08 PM   #4 (permalink)
ruger's Avatar
Well, I believe the top photo is often called the Scrambler Solo Seat.
I don't think the bottom one pictured takes a cowl. No side screw bosses.
The top one definitely takes a cowl without the rack attached. And it is very comfortable.
Ruger
Old 11-30-2012, 09:43 PM   #5 (permalink)
Main Motorcycle: 2005 Bonneville Black
Funkbyte's Avatar
Extra Motorcycle: 1975 CB550F Cafe'
I have the Sixty8 series seat with the cafe cowl. Thinking about where the screw holes are on it, I think they are roughly in the same place as the picture of the rack. The only difference I think is that from what I remember there is not much of a dip to the rear seat where as on the picture of the rack seat it looks like there is a significant dip, or just no rear seat at all. I will try to get a picture or two of my seat with, and without the cowl on for you tomorrow if I get a chance.
If the rack and cowl are interchangeable then that would be great for switching between a cafe and touring set up.
"Only a biker knows why your dog sticks its head out the window."
Keepin' the shiny side up, and rubber side down, since 2005.
Funkbyte is online now   Reply With Quote
Old 11-30-2012, 09:50 PM   #6 (permalink)
Moogs's Avatar
Just ordered it from MADDS. Seems to be a very flexible combo. Look forward to it.
Where do I get a cheap black cowel? Do I look for a Thruxton cowl somewhere?
Old 11-30-2012, 09:57 PM   #7 (permalink)
ruger's Avatar
That's the hard part. From what I hear the sixty8 cowls are discontinued. That's why I was asking about the Thruxton seats. But there's always ebay for either one. Or maybe some supplier will still have one in stock. They're not cheap new.
As for the dip, the cowl bites the seat the tiniest bit at the front middle but it looks great and doesn't leave a mark. The cowl screws on at the screws on the raised part of the sides.
FWIW, license plate reflector bolts are a perfect fit. I removed the stock side reflectors and use the red ones on my seat - cowl or no cowl. The cowl also fits the sixty8 Contemporary Seat which is smaller and more shapely than the stock seat.
Ruger
Old 11-30-2012, 10:05 PM   #8 (permalink)
Moogs's Avatar
So either cowl should fit? I am likely gonna get the bike painted at the end of the project so as long as I can find a cowl that fits thats sorta black for now ill be in good shape.
Old 11-30-2012, 10:13 PM   #9 (permalink)
Main Motorcycle: Goodwood Green Bonneville
capoanj's Avatar
Other Motorcycle: Yes
Extra Motorcycle: Several
Any cowl will fit the Single seat and rack with the rack removed. I've had this setup on my Bonnie for a while.
'06 Goodwood Green and '05 Black Bonnies
2011 Tiger 800- Fruit Rollup Green
1995 Daytona Super III
1989 Honda GB500/1968 Norton P11 Ranger
1961 Moto Morini Tresette 175
capoanj is offline   Reply With Quote
Old 11-30-2012, 10:45 PM   #10 (permalink)
Moogs's Avatar
How about this one?
Sixty8
Anybody have photos of the underside of the Contemporary Seat vs Single Seat and Rack parallelworld Twins Talk 10 12-12-2010 02:02 PM
single seat/cowl for tbs Dittos3 Hinckley Classic Triples 0 02-17-2009 07:21 PM
single seat cowl benny Hinckley Classic Triples 9 05-31-2006 05:11 PM
What's under the TBS single seat cowl? gregzilla Hinckley Classic Triples 9 09-13-2005 08:38 AM
single seat with cowl for legend camaromullet Hinckley Classic Triples 0 01-19-2005 10:38 PM
