11-30-2012, 05:06 PM
Grand Prix 250 Main Motorcycle: 2006 t100
spark plug socket
Did anyone recently purchase a socket or spark plug tool that definitely works for our bikes, and if so could you post me a link. I Just got my second one that I'm not able to use. Bought two already, one was too thick walled, one was too short to use a ratchet. Thanks much.
11-30-2012, 05:09 PM
Site Supporter SuperBike Main Motorcycle: 2007 bonnie black
Posts: 1,425 Other Motorcycle: 68 BSA (RIP)
craftsmen 18mm...look for the thin walled
Sent from my Galaxy Nexus using Motorcycle.com Free App
11-30-2012, 05:25 PM
Thanks Killian, but I got that one from sears, after searching on here...it's not long enough for the ratchet to turn it at all. i feel like it needs to be longer so it clears the cam covers and i can get leverage.
This is the one i bought.
http://www.sears.com/craftsman-18mm-...2&blockType=G2
11-30-2012, 05:59 PM
It works fine...just take the tank off
11-30-2012, 06:17 PM
Formula Extreme Main Motorcycle: 2008 T100
Perhaps you just need an extension to get up past the cam cover.
Chris
BIR# 309
08 T100 with AI removed, K&N Pods, BC Predators, 145 mains/42 pilots, no shim, -1 turn out @ sea level, green springs
11-30-2012, 06:28 PM
extension! that's what i need. thank you.
11-30-2012, 06:43 PM
They come in different lengths. Maybe by a set. You never know when you may have to combine more than one to give you the length that you need.
Chris
BIR# 309
11-30-2012, 08:08 PM
If you're willing to pay a bit more for a really nice tool, you can't go wrong with this:
http://www.amotostuff.com/product/MP08-0175.html
Can be found discounted for less if you look around.
12-01-2012, 01:37 PM
Powerbike Main Motorcycle: Thruxton 04
Posts: 392 Other Motorcycle: Ariel VHA Special Extra Motorcycle: Honda Pan European ST1300
I bought an 18mm box spanner and cut it down to just fit under the tank then cross drilled it for the tommy bar and a piece of washing machine hose to grip the insulator...They dont need much leverage as they should be done up tight enough to crush the washer.....
T.U.D.
