Triple Clamps and USD Forks - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 12 (permalink) Old 11-29-2012, 02:51 PM Thread Starter
Main Motorcycle: Thruxton
gerrieSTL's Avatar
Has anyone seen or tried the Free Spirits triple clamp offered on BelaCorse? http://www.bellacorse.com/bcc301.htm
The company, Free Spirits, did a Tridays bike that had USD forks. They also offer a triple clamp that accomodates USD Showa forks. Here is what they say: "Kit steering plates designed to accommodate USD Showa fork. Wheelbase as the original Speed ​​Triple, and caster as the original Triumph Bonneville. Are these fabulous CNC machined billet triple trees, to fit Triumph Bonneville t100. Can be adapted also for Thruxton, Scranbler, and SE. Available in either black or natural silver finish."
On the Free Spirits website, http://www.freespirits.it/prodotti.p...31&prod_id=961
, they do not have a price listed for the UST triple but I am assuming that they make them for production similar to the standard clamps.
My question is this, are there USD Showa forks that can accomodate the standard thruxton/bonneville spoked front hub? I know brand new fork tubes would be expensive but if we can get them from a current production bike that might keep the cost down. The BelaCorse price for the standard tree's is not as bad as I would have expected at $550. I know alot of people like to go to mag wheels for tubeless and weight but I like my spoked wheels.
I think even if I can't figure out the USD option I might order the standard clamps because they are very nice looking and would clean up the front end since I have a top tree with bar mounts and use clipons. Anyone got any thoughts on this?
gerrieSTL is offline
post #2 of 12 (permalink) Old 11-29-2012, 07:08 PM
Main Motorcycle: Two wheeled
Retro-Racer's Avatar
Other Motorcycle: several
Extra Motorcycle: next one
My understanding is that you would use the forks, wheel, brake(s) and axle from a donor bike, not reuse the Bonneville wheel, brake & axle. Exactly which model donor bike I cannot say at this point. I only have the 41mm Bonnie trees right now.
/M
"With integrity, nothing else matters. Without integrity, nothing else matters."
Retro-Racer is online now
post #3 of 12 (permalink) Old 11-29-2012, 09:58 PM Thread Starter
gerrieSTL's Avatar
Free Spirits also makes a dual disc hub for a triumph classic. If the USD fork is spaced properly could you just use spacers to make a wire wheel work with dual discs and the USD forks?
post #4 of 12 (permalink) Old 11-29-2012, 11:04 PM
Main Motorcycle: 05 thruxton, 06 scrambler
now THAT would be interesting. i don't want to run mag wheels, but have often entertained a front suspension/brake swap on my thruxton.
if a fork/caliper/hubbed wheel (with speedo) combo were available, i'd certainly be into it...
dwelle is offline
post #5 of 12 (permalink) Old 11-30-2012, 12:20 AM
El Moderatore
Main Motorcycle: 2007 Bonneville
Calliway's Avatar
Other Motorcycle: 2007 Kawasaki Versys
Holy Crap, those are nice. Now what.....cams or USD conversion....
Calliway is offline
post #6 of 12 (permalink) Old 11-30-2012, 10:01 AM
Main Motorcycle: 2004 Thruxton
Other Motorcycle: 1954 BMW R25/3
Extra Motorcycle: 1971 CB350
The operative phrase here is 'if the USD fork is spaced properly'. The fork spread would have to be perfect for the hub width in question to allow both right and left side rotors to line up with the calipers w/o having to fabricate caliper mounts...
Regards,
--Rich
beemerrich is offline
post #7 of 12 (permalink) Old 11-30-2012, 04:00 PM
Main Motorcycle: '05 Triumph Bonneville
Craigore's Avatar
Other Motorcycle: 47 FL Knucklehead
Extra Motorcycle: '74 RD350
phew, that's a lot of loot.
Craigore is offline
post #8 of 12 (permalink) Old 11-30-2012, 08:46 PM Thread Starter
gerrieSTL's Avatar
It is definitely part overload but for the extra $550 for the triples you get a part that looks awesome and matches the stock triumph mounting holes which allows me to keep my D9 bracket.
Now the problem is to go with the standard triple and bitubo internals or the USD triple and donor forks. The bitubo would be the easier route and save lots of time. But I definitely think going with the Free Spirits parts would make the USD forks look almost stock which would be pretty awesome.
post #9 of 12 (permalink) Old 12-01-2012, 12:46 AM
D9
D9's Avatar
I want one Mr Bellacorse maybe santa will be good to me this year.
D9 is offline
post #10 of 12 (permalink) Old 12-01-2012, 11:19 AM
Main Motorcycle: 04 Thruxton
Aussiematt's Avatar
Other Motorcycle: 13 Str Trple R
I am sure I read that they (the italian supplier) also manufactured a triple clamp for the thruxton.
FCR, Uni, 813 cams, Works shocks, drilled Ricor valves, Pieman ignitor, green springs, Beringer caliper, preds, damper, brace, Corbin, custom tinware, JMC swingarm, Brembo radial M/C, oil cooler, rearsets, clip ons, tubeless rims, Acewell, T/Clamp
Aussiematt is offline
Triple Clamps to fit speed triple for 53/56mm help CometMan Speed Triple Forum 8 10-09-2012 04:15 PM
TBS forks in TB clamps deadman Hinckley Classic Triples 2 09-02-2011 11:10 AM
How far can forks be raised in triple clamps? shoen Sprint Forum 26 03-31-2009 10:59 AM
Yamaha R1 forks and triple clamps on a bent sprint ? bueller T3 Sport / Touring Forum 3 04-19-2006 06:15 AM
