Regapping the crank positions sensor or ignition pickup coil - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGearMotorcycle.comMotorcycle.com Classifieds!
Old 11-27-2012, 04:50 PM   #11 (permalink)
Main Motorcycle: Bonneville
Other Motorcycle: Honda Postie
Extra Motorcycle: Suzuki DL650 V Strom
Hello
Yes I have had an intermittent problem of engine cutting out suddenly and then failing to start only to fire up some time later. I am pretty sure now that the problem is bad contact in the igniter plug. I am going to investigate clearance between the plug and the seat pan. If it is too close I will relieve the seat pan to provide more clearance. I will report back in due course.
Tasmaniablue is offline   Reply With Quote
Old 11-27-2012, 05:37 PM   #12 (permalink)
Main Motorcycle: 2008 T100
bluesforchallah's Avatar
Lucky, the issue with your bike stalling at the red light is eerily familiar of my issue. Before you tear into the alternator cover, in addition to the air mixture screw rebuild kit, try blowing out the air mixture screw and pilot jet holes with carb cleaner and compressed air like I suggested. Also, have you had your carburetors balanced recently?
The symptoms sound more like an air/fuel ratio issue than an electrical/ignition problem.
Three Carburetor Problems:
1) Rich Mixture means the carburetor is delivering too much gasoline. Typical symptoms of a rich mixture are:
Poor fuel economy
Sluggish acceleration
Choke not needed from cold starts
Sooty or black spark plugs
Sooty or black muffler end pipes
Strong smell of gasoline when machine is at idle
Uneven running (will often slow from regular idle rpm's and stop)
2) Lean Mixtures means the carburetor is delivering too much air. Typical symptoms of a lean mixture are:
Backfires as the throttle is closed (primarily during coast-downs)
Lurching acceleration
White or light grey spark plugs
Requires excessive amounts of choke to run/start
White or light grey muffler end pipes
Bluing (on chrome systems) of the exhaust header down-pipes
3) Incorrect Adjustment applies to carburetors that have incorrect adjustment of the air/fuel screw and the balance between two or more carburetors - where fitted. Incorrect adjustment can produce any of the previously noted symptoms. On multi-cylinder machines, with separate carburetors for each cylinder, the following symptoms are typical of an adjustment problem:
Poor overall performance
Rattling sounds from the clutch
Engine tends to stall easily
Erratic acceleration
Poor fuel economy
Misfires and/or backfires
Edit: I also found this to be very beneficial for understanding how each of the different components of the carb work. I was completely clueless.
http://www.duncanracing.com/TechCent...arbJetting.pdf
Chris
BIR# 309
08 T100 with AI removed, K&N Pods, BC Predators, 150mains/45 pilots, no shim, -2.0 turns out @ sea level, green springs
bluesforchallah is online now   Reply With Quote
Old 11-30-2012, 08:56 PM   #13 (permalink)
Good reference blues.
I think I need to sort out any leaks on this bike first like you have advised me. New o-rings and mixture screws are going on this weekend followed by new rubber intake boots and stainless clamps.
luckyduck is offline   Reply With Quote
Old 11-30-2012, 09:17 PM   #14 (permalink)
Main Motorcycle: 08 Bonneville Black
ruger's Avatar
Originally Posted by luckyduck View Post
I'm thinking I need to do this more and more. Bike just died on my at a stoplight today. Second time this has happened.
I'm worried it's an ignitor problem. That's a $250 problem right there and I'm not quite ready to confront it haha!
I guess I should just go for a procom unit.
If it runs well until it warms up and then quits, try the ignition coil first. Might save you a bunch of dough-re-mi.
Ruger
Long may you run-Neil Young
ARK/Dominators/Works/Progressive/EBC rotor/Rocket III master cyl/Pazzos/170 rear/TPUSA tach kit/520 kit,19T/Denalis/Bashplate/DEcosse MOSFET upgrade/More crud/Ruger's Garage
ruger is offline   Reply With Quote
Ignition pick-up coil / Crank position sensor (nerdy AND boring) Forchetto Twins Technical Talk 125 05-13-2013 03:29 PM
Ignition Pickup Sensor ByTheLake Hinckley Classic Triples 10 04-30-2013 08:08 PM
Crankshaft positioning sensor, Pickup coil Mattybee Tiger Workshop (archive) 1 10-26-2009 06:49 AM
coil / ignition sensor fastfreddie T3 Sport / Touring Forum 32 03-04-2007 05:11 PM
