Transmission cover disassembly - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-25-2012, 09:50 AM   #1 (permalink)
Main Motorcycle: 2008 Thruxton
Primary, gear-case, transmission. Call it what you will, mine needs to be disassembled . I took a low speed spill and want to get the scrape polished out and re powder coated. I am going to be taking the cover apart myself and sending it to my dealer to have repaired and powder coated. The only issue I am having is a technical publication to do this with. I do not have a manual on hand to disassemble the cover. I am sure I can do it on my own, but I prefer to do it correctly without any incident. I have one on order but I am supposed to drop off the cover on tuesday to my dealer. Does anyone have the ability to scan a few of the steps along with the associated parts diagram into a PDF? I would be thankful. I suppose if this is against the forum rules it shall be deleted promptly. But it never hurts to ask. Thanks in advance.
d3v1c3 is online now   Reply With Quote
Old 11-25-2012, 10:59 AM   #2 (permalink)
Main Motorcycle: 2012 EFI Thruxton 900
Hotboppincat's Avatar
Other Motorcycle: Honda CBF 125 2011
Which side?
Do you want to remove the clutch cover on the left as you are sitting on the bike?
Hotboppincat is offline   Reply With Quote
Old 11-25-2012, 11:08 AM   #3 (permalink)
Main Motorcycle: Triumph Thruxton EFi
Other Motorcycle: Yamaha R1, Honda CB1000R
There's not really too much to 'disassemble' with the cover only the clutch release mechanism which going from memory pretty much just drops out, depending on what you are doing you may also have to remove the needle roller bearings for the clutch shaft and gear change lever but unless you're going to powder coat it I'd leave them alone, it's all pretty intuitive once you look at it, I didn't have a manual when I did it, take some photo's as you do it so aid re-assembly.
One thing to make very , very sure of is that the starter idler which sits on a shaft which engages at either end on the inner and outer (the one you're removing) case. When you disassemble this shaft can pull out of the engine side case and the gear shift it's position, it can look correct but if you leave it like that it will all attempt to self destruct when you try to start the engine.
GDCobra is offline   Reply With Quote
Old 11-25-2012, 11:11 AM   #4 (permalink)
http://www.worldoftriumph.com/triump...lock_03=232888
Exploded parts diagram here covers both sides.
Old 11-25-2012, 11:18 AM   #5 (permalink)
Thank you for both replies. That will help me out tremendously.
GDCobra, once the cover was removed the only loose parts that I noticed were the; wavy washer (which I did not see on the exploded parts list), and the dowel rod. everything else seems to be in its place still. I suppose once I get my manual in the mail everything should go back together fairly easily.
I noticed you said "unless you're going to powder coat it" did you mean me personally? I was going to have a professional do all of that so I suppose I can just leave the bearing in.
Old 11-25-2012, 11:31 AM   #6 (permalink)
I just looked at the Haynes, the 4 cover dowels, the starter gear wave washer, and shaft are the only bits you are likely to lose. I can't scan the Haynes and upload it, cos of copyright.
But it goes something like this:
Drain the oil
Remember the position of the gear lever for reassembly. Undo pinch bolt and remove linkage.
Remove the clutch cable from the arm.
Remove breather hose from crankcase
Unscrew the bolts
Take the cover off.
Remove the old gasket
(Keep the 4 locating dowels safe, remembering where they go.)
Keep the wave washer safe, the shaft will pull out of the starter gear too..
I think thats it.
Old 11-25-2012, 11:36 AM   #7 (permalink)
Perfect. that will at least allow me to take care of everything until my manual arrives. Thanks for all of the help.
Old 11-25-2012, 11:46 AM   #8 (permalink)
Yeah, forgot about the wavey washer but the important thing is when you put that 'dowel' back in that it engages correctly with the bore in the inner case, that's the main 'gotcha' with this cover. Your powder coaters may take the bearings (and the associated oil seals) out and chuck them away (you may be replacing them anyway), I'd check with them the best thing to do before leaving it with them.
Old 12-23-2012, 04:37 AM   #9 (permalink)
Main Motorcycle: Bonnie
Mvke's Avatar
Other Motorcycle: Mv,s
Extra Motorcycle: Brutale Starfighter
Gonne do the same job as you did , what manual are you talking about , would like that one.
Mvke is offline   Reply With Quote
Old 12-23-2012, 05:11 AM   #10 (permalink)
Legend
Forchetto's Avatar
Probably this one:
http://www.haynes.co.uk/webapp/wcs/s...egory_rn=10501
Removing transmission cover, 07 Thrux jguzzi Twins Technical Talk 5 10-01-2011 07:24 AM
Transmission cover leaking tobydmv Classic, Vintage & Veteran 8 03-25-2011 02:04 PM
touching up black transmission cover CaliforniaKevo Twins Technical Talk 4 09-03-2008 07:50 PM
5 speed outer transmission cover TheBondoBandit Classic, Vintage & Veteran 2 04-21-2005 02:37 AM
outer transmission cover TheBondoBandit Classic, Vintage & Veteran 7 04-11-2005 12:44 AM
