One shim or two? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-23-2012, 05:32 PM   #1 (permalink)
gjones's Avatar
One shim or two?
What theoretically, would be achieved by adding another shim?
This is my setup:
2006 T100
140/42 jets
NBZT needles
1 x 0.5mm shim
Idle mixture screws 3 turns out
It runs pretty good
gjones is offline   Reply With Quote
Old 11-23-2012, 05:45 PM   #2 (permalink)
Main Motorcycle: 2004 Bonnie Black Special
PieMan's Avatar
A slightly richer bottom end/mid range.
Mike (UK)
PieMan is online now   Reply With Quote
Old 11-23-2012, 06:19 PM   #3 (permalink)
Main Motorcycle: '06 T100
Bron-Yr-Aur's Avatar
Other Motorcycle: Kawasaki KXdirtshredder
Extra Motorcycle: '76 Tiger 750
I don't speak out of posing to be a mechanic, only because I have the same bike.
Even with wide open pipes and Thrux needles (sorry I don't know the code, I think that's the needles you have) you should not need a shim, ever, and 3 turns is waaaaay too rich.
With 42's mine ran great at 1 1/4 to 1 1/2 turns, no shims, and that was on a dyno, not guessing with me arse. At 2 1/4 turns, I smell raw fuel.
Just my personal experience.
Bron-Yr-Aur Garage
Bron-Yr-Aur is offline   Reply With Quote
Old 11-23-2012, 07:03 PM   #4 (permalink)
+1. Mine stinks of raw fuel on tickover with the mixture screws anything over one turn with 42 pilots ...thrux needle (NBZT), no shims.
Old 11-23-2012, 08:38 PM   #5 (permalink)
gjones's Avatar
Thanks for replying.
The three turns-out wasn't arbitrary - it was the point reached that stopped the bike backfiring and made it run better than ever.
Old 11-23-2012, 08:41 PM   #6 (permalink)
gjones's Avatar
... by mid-range, I take this to mean better acceleration in higher gear at higher speeds, right?? - this is precisely what I'm looking for
I'm not exactly sure what you mean by "bottom end" though ....
thanks,
GJ
Old 11-23-2012, 09:48 PM   #7 (permalink)
B02S4's Avatar
Mike was referring to throttle position, not vehicle speed or gearing. Presuming you have the correct size mains, with NBZT needles, as a general rule, shims should not be necessary.
B02S4 is offline   Reply With Quote
Old 11-24-2012, 12:28 AM   #8 (permalink)
Bottom end is your lower rpm range, the twisting force (torque) off idle. B02 made a good point: you have to make sure you're running the right mains. What pipes are you using?
Bron-Yr-Aur Garage
Old 11-24-2012, 09:51 AM   #9 (permalink)
gjones's Avatar
I take your point. So essentially there is an equivalency of sorts in raising the needle to allow more fuel, and increasing the jet size, correct?
Could you suggest any metrics that could describe this i.e: jet size increments and 0.5mm shim equivalencies ?
thanks,
GJ
Old 11-24-2012, 09:56 AM   #10 (permalink)
gjones's Avatar
Both the air intake and exhaust are low restriction.
thanks,
GJ
Do I have a shim? Arkwright Twins Technical Talk 10 11-18-2012 06:22 PM
Which Shim Kit? phpbiker T3 Sport / Touring Forum 4 01-05-2012 08:56 AM
Swingarm Shim swgee Classic, Vintage & Veteran 6 10-21-2009 07:10 AM
To shim or not to shim... Kramocker Twins Technical Talk 6 12-07-2007 10:05 PM
to shim or not? msioda74 Twins Technical Talk 4 10-16-2007 09:20 AM
