11-24-2012, 10:18 AM
#11 (permalink)
SuperStock Main Motorcycle: Thruxton
Posts: 276 Other Motorcycle: Rieju Tango
Originally Posted by kreemsicleT100
Even with wide open pipes and Thrux needles (sorry I don't know the code, I think that's the needles you have) you should not need a shim, ever, and 3 turns is waaaaay too rich.
I can assure you that with my setup a shim is certainly needed. Open pipes, thrux needles and de-baffled air box + breathe.
07 Thruxton: TEC 2 into 1, K&N, TTP Breathe Bellmouth, 135 mains, 40 pilots, std. needles, 1 shim (0.65mm). All baffles removed. Bitubo Fork Cartridges. Bitubo Rear Shocks. TEC Steering Damper. 3 Pot Nissin (Honda) brake caliper.
11-24-2012, 12:00 PM
#12 (permalink)
Site Supporter SuperBike Main Motorcycle: 2004 Bonnie Black Special
But you're using a 40 pilot Gary, if you moved to a 42's you possibly wouldn't need a shim.
11-24-2012, 02:14 PM
#13 (permalink)
SuperSport Main Motorcycle: '06 T100
Posts: 1,370 Other Motorcycle: Kawasaki KXdirtshredder Extra Motorcycle: '76 Tiger 750
After reading many, many posts on this, when setting up my bike, here's what I came up with...
For 865 motors, pods and open exhaust, the guys who were tested and tuned, I saw this pattern: mains, range of 140 to 155. This varied greatly depending on location and weather, but this is the most important factor in tuning, because everything else is affected from the mains down. The mains have to be correct (WOT) to get the low (idle to 1/4 throttle, pilots) and mid range (needles) power right. So I started with a 147.5. (I ended up needing 152's) With Thrux needles, I never saw a member use shims, and my dyno/sniffer confirmed this. With 42 pilots, I saw most members between 1 and 2 turns. Mine is happy around 1 1/2, until lately with crazy weather changes. And the only reason I question them now is difficulty starting when below 40°.
By no means am I a genius at this, which is why I research like I do, but I'm just sharing what a couple of months of research yielded for me. I'm sure others may have a different experience, but I tried to take all things into consideration, at least to establish some sort of baseline. Hope that helps, at least a little.
Bron-Yr-Aur Garage
11-24-2012, 04:22 PM
#14 (permalink)
Supersport 600 Main Motorcycle: Bonneville T100
Sure, and I appreciate your input.
My existing set-up is working very well for me. Having found the right configuration, it provides the performance benefits that I expected.
However, I find that in top gear at speed, when I want to pass traffic, given the choice to gear down and accelerate, or to just accelerate, I tend to choose the latter.
So my question regarding shims was to discover whether, theoretically, an extra shim would increase acceleration under these conditions, or not.
11-24-2012, 09:11 PM
#15 (permalink)
Originally Posted by gjones
...So my question regarding shims was to discover whether, theoretically, an extra shim would increase acceleration under these conditions, or not...
IMO, if the current mains are too small for optimum WOT performance (& I believe the 140's in yours probably are sub-optimally on the lean side), then yes, it is theoretically possible.
An AFM in actual on-road conditions will show AFR indications that you simply can't feel, & the difference between "OK" & "WOW" can sometimes be just a step or two off.
Also IMO, you can get to "good" with seat of the pants carb tuning, however if you want to get to "great" there really is no substitute for tuning with a AFM.
11-25-2012, 10:48 AM
#16 (permalink)
Originally Posted by B02S4
...the difference between "OK" & "WOW" can sometimes be just a step or two off.
well, that's quite motivational.
hmmm.... I have 145s in my box that I could try.
thanks, GJ
11-27-2012, 10:30 PM
#17 (permalink)
Formula Extreme Main Motorcycle: Bonneville black 2007
Posts: 933 Other Motorcycle: i'm poor only own one
I would think the larger jet would give better roll on throttle response if that is what you are looking for. Try it out and decide for yourself. Can't hurt anything. Having the bike tuned on a dyno is the best way to go and then you are not guessing at this stuff. But then what happen to all the fun with a dyno. LOL.
