Tire Tube troubles - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-22-2012, 04:55 PM   #1 (permalink)
Main Motorcycle: '09 Triumph Thruxton
Burgandy25's Avatar
Other Motorcycle: 1978 schwinn le tour
Tire Tube troubles
I'm buying new tires and am looking at getting new tubes also but I cannot find tubes that will fit the front tire can anyone shed some light or tell me where I can get tubes that fit?
Burgandy25 is offline   Reply With Quote
Old 11-22-2012, 06:40 PM   #2 (permalink)
https://www.denniskirk.com/metzeler/...prd/650052.sku
Marty
Old 11-22-2012, 07:29 PM   #3 (permalink)
Main Motorcycle: rotates daily
ItsForrest's Avatar
Other Motorcycle: Aprilia Scarabeo 500ie
Is the front tire on a Thruxton an 18 or 19?
I've seen it listed as both. On one web page listing specs, it has a 19 rim and an 18 tire.
The urge to buy terrorizes.
'08 Scrambler - work in progress...
ItsForrest is offline   Reply With Quote
Old 11-23-2012, 12:27 PM   #4 (permalink)
Main Motorcycle: 08 Bonneville T100 C/S
wenzel850's Avatar
Motorcycle Superstore. I buy the Michelin tubes, expensive but so far never had a problem.
Quentin
wenzel850 is offline   Reply With Quote
Old 11-23-2012, 11:41 PM   #5 (permalink)
gjones's Avatar
Agreed, the Michelins are good quality, and I'm not about to go cheap on what connects me to the planetary surface.
Best extra 5 bucks ever spent.
gjones is offline   Reply With Quote
tire tube question tsx123 Twins Technical Talk 1 07-26-2012 04:22 PM
URGENT: Can I replace only the inner tube or do I need to replace tube and tire? tooblekain Twins Technical Talk 6 08-12-2010 07:48 PM
tube size for 150/70 tire bonniemike Twins Technical Talk 1 01-15-2010 03:35 PM
Tire ..tube Ques Boriqua Twins Technical Talk 9 10-16-2007 08:42 PM
tire tube mayfiebl Twins Technical Talk 1 02-26-2007 09:14 PM
