I decided the front fender on my Scrambler needed a little extra something to offset all of that Fusion white. (I always swore I would never own a white motorcycle but this one is really starting to grow on me.) I pulled out the dremel tool and took about 1 1/2 inches off of the front and rear of the fender. If anyone else decides to go down this path, be careful and use a real low speed on the dremel, the plastic will melt if you cut too fast. Next, off to Pep Boys to match the Tornado Red with Duplicolor and I got pretty close with a Milano Red spray can. I also picked up some gold pin striping to coincide with the tank trim. I laid the red and pin striping with a couple good coats of quality clear and a new look for the fender for about $15.00.
