Hey plumpton make sure when you loosen bolts, do so that you break em all free and turn each one a turn or so at a time until there out & tighten them finger tight same way then start to torque down a 1/2 turn or two at a time. This should prevent warping cam cover & keep seal in place. Give it a once over before you fully commit to torque spec & inspect seal for consistent mating. Good luck!
