Headlight issues - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-13-2012, 05:37 PM   #1 (permalink)
Main Motorcycle: Triumph Bonneville 2001
Headlight issues
Hello all
Ive had my 2001 Bonnie for a while now, but recently my MOT guy realised my headlight is not uk spec as it shines the wrong way. I'm miffed now why my Bonnie has/had a non uk spec headlight. Could I tell by the frame number if it,s from outside the uk market ?
Ive had to buy a headlamp from Germany. yes it's uk spec but ive had to drill a new screw hole in the headlight shell to line the lamp up otherwise the reflective lines on the back of the lamp vere to the right.
curious if any one else has had headlight issue's . Ive put a blue 100watt bulb in. Bright as ! though ive really struggled to get the parking bulb in as it just drop's out of it's holder when i try to fit !
Gray
petruckevitch is offline   Reply With Quote
Old 11-13-2012, 06:04 PM   #2 (permalink)
I'm questioning the wisdom of fitting a 100w bulb. It will melt the wiring and they're illegal in the UK.
Old 11-13-2012, 06:11 PM   #3 (permalink)
Legend
Forchetto's Avatar
I was thinking that. The bulbholder won't like it either. The contacts will lose their temper, create some resistance which will lead to it getting hotter, etc, etc.
Forchetto is online now   Reply With Quote
Old 11-13-2012, 06:48 PM   #4 (permalink)
Once had a guy came into the garage asking me to replace a blown headlight bulb. Turned out it wasn't the bulb that had blown, the last 12 inches of wiring and connectors were toasted after he fitted 100w ones the previous week.
Old 11-13-2012, 06:56 PM   #5 (permalink)
right ? well the bulb's been working fine with no damge to wiring etc. thanks for your feedback.
Old 11-13-2012, 07:09 PM   #6 (permalink)
It will for a while... until the heat gradually melts the wiring insulation and pops the fuse.
Legally - 100w+ bulbs are for off road use only.
Old 11-14-2012, 04:59 PM   #7 (permalink)
yep ! unless i upgrade the wiring it's a risk running a high wattage bulb. Ive replaced the bulb and modified my non uk spec headlight shell. All good
Old 11-14-2012, 07:15 PM   #8 (permalink)
Main Motorcycle: None at this time
Just my 2 cents worth here. Your headlight runs from 12 to approx 13.5vdc with a current draw of 5.4 to 4.8 amps respectfully
for the 65 watt high beam.
For a 100 watt bulb for the same voltage will draw 8.3 to 7.4 amps. This is quite a jump and you will have to change more than the wire. I would use a relay to control the headlight with heavier wire going directly to the battery with a ceramic H4 connector. Eastern Beaver (no affiliation) makes H4 Heavy Duty Single Headlight Relay Kits with Ceramic H4 Socket that will do the job. Here is the site: http://www.easternbeaver.com/Main/Wi...s/h4_kits.html
I will not comment on want is legal in the UK but I am pretty sure in Canada that it is not.
biker222 is offline   Reply With Quote
Electrical Issues; Headlight rivera Classic, Vintage & Veteran 7 09-20-2009 04:31 AM
S4 headlight issues. Bradfl Triumph SuperSports 9 12-22-2008 04:39 AM
Headlight Issues ????? skoobi Trophy 2 08-14-2008 12:00 AM
new owner/headlight issues glassbreaker Trophy 4 08-12-2008 08:30 PM
headlight issues ferris11 Speed Triple Forum 12 09-19-2004 07:12 PM
