If it makes you feel any better my '05 Thruxton has been having similar problems.... secondary coil is in spec, but the primary coil is at 0.8 ohms. My first coil died after just over three years, coil number two just died, and coil number three is on the way, hope it corrects the problem... hope it also lasts longer than three and a half years...
~Wiseco 904~39mm FCRs~'01 790 cams~shim-under-bucket~+1.5mm valves~doubled valve springs~flowed head~Procom programmable CDI~Race Tech springs & Ricor Intimators~Hagon Nitros~Pretech 6-piston caliper~48mm headers~wide 17" rims & sticky rubber~
