Will it run? Taking bets! - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-12-2012, 01:03 AM   #1 (permalink)
Main Motorcycle: rotates daily
ItsForrest's Avatar
Other Motorcycle: Aprilia Scarabeo 500ie
After a few hours in the garage I have just a couple little things to button up. Then I will hit the starter and see if I screwed it all up or made it better.
Place your bets!
It's an '08 Scrambler, the US version with carbs. The bike now has stock pipes with the baffles yanked. Opened up the airbox this evening and pulled the baffle and snorkle and opened up the air filter retainer. AI came out last week.
Jets are now 130 mains, stock pilots, 1 shim under the needles and pilot screws out 2-1/2 turns. I'm at sea level.
I'm guessing the mains are good but it's going to be rich on the pilot screw and needles. I'll have to wait till tomorrow to ride it and see.
The urge to buy terrorizes.
'08 Scrambler - work in progress...
ItsForrest is offline   Reply With Quote
Old 11-12-2012, 01:07 AM   #2 (permalink)
I don't see why you'll be rich on the pilot screws or the needle.
I'm running a similar setup to yours on my Bonnie but:
-NH Togas installed
-Baffled not removed yet
I'm running the 42 size pilot jets with the screws turned 2 turns out.
I have a vacuum leak on my bike right now so I can't comment on the performance but I don't think you'll be rich on your pilots or your needle.
Just my opinion though. And I'm sure it'll start just fine.
luckyduck is offline   Reply With Quote
Old 11-13-2012, 12:43 AM   #3 (permalink)
ItsForrest's Avatar
Took it out for about 50 miles of mostly freeway driving today. It runs very nicely. If it is a little rich it doesn't feel like it. It has great throttle response and pulls strong with no bog or hesitation that I found. With traffic I didn't get an opportunity for a good pull on the main jets but the mid range is great.
Old 11-13-2012, 07:06 AM   #4 (permalink)
Main Motorcycle: '06 T100
Bron-Yr-Aur's Avatar
Other Motorcycle: Kawasaki KXdirtshredder
Extra Motorcycle: '76 Tiger 750
Since we're just playing and you're taking bets, my guess is you're a little lean on the mixture screw and rich on the needles. Even with wide open exhausts, the stock cvk's usually don't need a shim (assuming you're using the stock needles? I think the factory started using Thrux needles around '06, but I'm not sure). And the stock setup uses 2 1/2 turns, which is already running lean from the factory. So that's my bet.
Bron-Yr-Aur Garage
Bron-Yr-Aur is online now   Reply With Quote
Old 11-13-2012, 11:38 AM   #5 (permalink)
ItsForrest's Avatar
Well, it's been hard to find good data for people using stock, or modified stock, exhaust with airbox mods. I found the link below from Ventura's thread when he was doing the A/F meter thing. He was using a Zard exhaust. With these aibox mods, he was using 130 mains, no shim and 1.75 turns.
http://www.triumphrat.net/twins-tech...esults-11.html
If all else is equal, I should be able to lean things out a bit. I do wonder about the effects of our 10% ethanol gas here. It does lean things out so maybe I'm closer after all...
Old 11-13-2012, 11:44 AM   #6 (permalink)
Listen to Ventura and shouldn't go far wrong.
taking gauges apart..... kuch73 Twins Talk 3 05-27-2008 10:09 PM
taking off from first gear metasac Twins Technical Talk 8 05-14-2008 09:57 AM
I was taking off my wheels and... 02trumpet Twins Technical Talk 9 03-30-2008 01:21 PM
NEED Help taking my tt 600 apart jeedizzle Triumph SuperSports 4 08-15-2007 07:51 PM
taking off the S4 hat S4fanatic Triumph SuperSports 12 05-22-2006 05:52 PM
