11-14-2012, 08:28 PM
#41 (permalink)
Formula Extreme Main Motorcycle: 01 Bonneville
Why are we comparing apples to oranges. The only thing a Tiger and Bonneville have in common are they are both motorcycles made by Triumph which if memory serves me correctly share some transmission components and thats about it. They are purpose built vehichles with different purposes.
If Rotella meets your needs great. I have used the product and was disatsified with it. I didnt save money using, I had to dump it after a 1,000 miles because the bike didnt shift correctly and the clutch was "sticky". Replaced with Mobil 1 20w50 Vtwin and all my headaches disappeared. I also suspect it has more in common with 15w50 Triumph Mobil 1. Both were high zinc oils. The product is available everywhere and is reasonably priced.
11-14-2012, 10:28 PM
#42 (permalink)
Supersport 600 Main Motorcycle: 2006 Bonneville T-100
I just picked up Mobil 1 at a local auto zone for $10 a quart. As far as I'm concerned, that's a pretty ****in cheap way to keep the bike running strong.
Oh, and Denbow... The title of the thread didn't tip you off to how this discussion was going to go!!??
11-14-2012, 11:06 PM
#43 (permalink)
Site Supporter World SuperBike Main Motorcycle: 08 Bonneville Black
Yes indeed. We're all friends here anyway.
But I'd like to know whose wheels are the roundest.
Certainly has to be one of our twins because all the other bikes suck.
• Ruger •
Long may you run-Neil Young
ARK/Dominators/Works/Progressive/EBC rotor/Rocket III master cyl/Pazzos/170 rear/TPUSA tach kit/520 kit,19T/Denalis/Bashplate/DEcosse MOSFET upgrade/More crud/Ruger's Garage
11-15-2012, 05:47 AM
#44 (permalink)
Formula Extreme Main Motorcycle: Suzuki GSF 1250S Bandit
Jag
I'm keeping my my head down
11-15-2012, 10:57 AM
#45 (permalink)
Grand Prix 500 Main Motorcycle: Triumph America
I didn't skim all the pages here, but I do want to point out, Rotella T6 is not the same as Rotella T.
I believe T6 is 5W-40, T is 15W-40, so maybe the lighter cold viscosity is what causes issues? I also think T6 has some FM added to it, which could cause slip. I use "regular" T myself, no issues in my engine, so I'm curious. I'd also recommend the 15W-40 over 5W-40 anyway.
Not sure we're all talking about the same type of oil, or only brand, but I've seen similar things happen elsewhere - some engines just don't like otherwise great oils.
And I don't hold stock in any of these companies, but i do want to point out, there's a difference between "cheap" oil and "not-marked up" oil. Rotella is an excellent oil that doesn't carry the official motorcycle label and thus doesn't have the usual motorcycle price markup. It works great for many motorcyclists which is why its so popular.
11-15-2012, 04:38 PM
#46 (permalink)
SOTP Vintage Series Main Motorcycle: 03 T100
I think you are right rotella t not t6 is what works good in our bikes.You should never use car oil with fm added in these bikes.You shouldnt use moble 1 car oil with fm in it ether.but you can use other moble 1 designed for bikes with out fm added .
11-15-2012, 11:32 PM
#47 (permalink)
SuperBike Main Motorcycle: '08 claret bonnie
Posts: 1,494 Other Motorcycle: '69 Kawasaki Samuri
Challenge
Originally Posted by mikeinva
It would not be fair to you you have a smaller motor your 1050 to my 1087.The 113 hp is that not what triumph rated your bike at? if thats the case thats crank hp you are only makeing around 100 at the rear wheel on the dyno.That will not be enough.140 mph wont cut it ether I will have a easy 10 to 20 mph on you in top end.that is with 9000 rpms.I wouldnt want to take your money you dont have a clue what a bonnie can be made to do.
Tell you what ill hook you both up behind my 550 hp detroit and i wont use the throttle!
11-15-2012, 11:56 PM
#48 (permalink)
Rotella
Rotella T6,T5, T, T and T1 are all diesel engine oils. Indeed they if used as specced can give warranties to engine wear up to 800, 000K. Maybe that is why triumph dont reccomend them?
All the above are CI or CJ rated C = commercial
Think of SH S= Service or spark plug.
Thr above diesel oils in there latest guises are designed to cope with extremely high comp motors with top rings running at extremely high temps. Some modern motors ( big hp) have ceramic 2 part pistons.
The C ratings have to cope with the new wave of EGR motors, where exhaust gas (a part) is returned to the combustion chamber for another go. These motors mostly us run very hot.
The big issue with diesel is Ash and soot and crappy sulphur contents can be a real headache, causing excess oil consumption on low mileage motors. Trying to find an oil for a mixed fleet used to be a nightmare.
Me i will stick with Triumph and Forchettos reccomendations.
Rotella is cheap because bit more produced than m/cycle oil
11-16-2012, 10:13 AM
#49 (permalink)
Fwiw, the Rotella oils have all passed JASO specs and some are actually certified. No reason to call them diesel oils - all oils are basically the same but for the additives put in them. There's nothing extra special about motorcycle additives to justify the price hikes for motorcycle-branded oil other than the fact that oil companies can get away with it.
One thing to remember in general, any multi-weight oil is basically a lighter weight oil "buffed" to make the heavier weight viscosity when hot. A 5w-40 may just be too thin a 40 weight while a 15W-40 is not. Either way, if I was going to put Rotella into a bike, I'd put the 15W-40 in.
One think I like about the "old" style oils though is that the formulations still focus on engine protection, and not a compromise between protection and mpg.
11-16-2012, 11:42 AM
#50 (permalink)
Ok can I use the KW in my driveway lol.
