Thumbs down for Rotella T6 - Page 3 - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!SportbikeTrackGear
Old 11-13-2012, 07:02 PM   #21 (permalink)
It doesn't say anything here about T6 being suitable for bikes, only DIESEL cars, trucks and buses.
http://www.epc.shell.com/Docs/GPCDOC...US)_TDS_v1.pdf
Old 11-13-2012, 08:46 PM   #22 (permalink)
B02S4's Avatar
Originally Posted by denbow View Post
It doesn't say anything here about T6 being suitable for bikes...
Yes it does. T6 is JASO-MA rated. It shifts just fine in my 865/270, although in hot weather the oil temp runs a bit hotter with 5/40 T6 than it does with Mobil-1 15/50
B02S4 is offline   Reply With Quote
Old 11-13-2012, 08:59 PM   #23 (permalink)
Main Motorcycle: 2007 Triumph T-100
Other Motorcycle: 79 Bonneville "GONE"
Extra Motorcycle: 1972 DeTomaso Pantera
Originally Posted by Forchetto View Post
It doesn't seem to meet the Factory specs, clearly stated in the handbook, either in viscosity or classification. It's also an "energy saving" oil which has been known to interfere with wet clutches.
Why not just stick to the Factory recommendations?, I quote:
"...semi or fully synthetic 10W/40 or 15W/50 motorcycle engine oil which meets specification API SH or higher (i.e. SJ, SK or SL) AND JASO MA..."
Gee Forchetto why would you think that the factory would know which oil to use ? Especially when I can save a few bucks !
Barnstorm is online now   Reply With Quote
Old 11-13-2012, 09:30 PM   #24 (permalink)
Main Motorcycle: 07 Tiger 1050
duncan67's Avatar
Other Motorcycle: 07 Tiger 1050
Extra Motorcycle: Bonneville America
The stuff works great in 1050 engines and IS rated for use in motorcycles with a jaso rating. Im thinking it has something to do with the sloppier tolerances of the p twin tractor motor needing thicker oil.
I admire harly riders greatly.How brave they must be to take to the hiways and byways on a motorcycle so bereft of handling and horsepower!
duncan67 is offline   Reply With Quote
Old 11-14-2012, 12:28 AM   #25 (permalink)
Main Motorcycle: 2009 Triumph Speedmaster
Other Motorcycle: Yamaha Seca Turbo
OIL is the cheapest form of insurance to keep the engine in good shape. Go ahead and put the cheap stuff in, save a few pennies, cents, centimes, and then shell out some really BIG POUNDS, DOLLARS,FRANCS; when you replace all the parts later. Don't start WHINING about your bikes longevity because it'll definitely WHINE when its gears and bearings get fed cheap oil.
mcfcinusa is offline   Reply With Quote
Old 11-14-2012, 10:54 AM   #26 (permalink)
Main Motorcycle: '06 Scrambler/'07 BonnieB
cdubya's Avatar
Other Motorcycle: '05 Yamaha WR 250
Extra Motorcycle: '05 Tiger
'06 Scrambler: De-AI'ed, CARK/Pods, Emgo 12" Shorty's, 145mains, 40pilots, stock needles, no shims
'07 Bonnie Blk: De-AI'ed, De-Snorked, K&N + NH Peashooters, 118mains, 40 pilots, one shim
'05 Tiger 955i: No airbox plate, Debaffled stock exhaust
cdubya is online now   Reply With Quote
Old 11-14-2012, 12:00 PM   #27 (permalink)
Main Motorcycle: 03 T100
mikeinva's Avatar
lol our tractor motors are about the same spec as your wanttabe rice rocket.
Old 11-14-2012, 12:19 PM   #28 (permalink)
duncan67's Avatar
Same specs really?! I own both,I know better. 113 hp in the wannabe rice rocket to the 60 hp in the bonny . Liquid cooled engine made to tighter tolerances engineered for the output and revs. 9500 redline for the tiger somewhere around 7 for the bonny. Top speed of around 140mph for the tiger and about 110 or so for the bonny,with tail wind. The list goes on. Rotella has a great track record for the 1050 motors,many of us use it with results indisernable from bike specific higher priced oil. Its cheaper,more readily available and does the same work. I stll use bike specific stuff in the bonny because she doesn't get ridden that many miles a year compared to the wannabe,lol.
Old 11-14-2012, 12:43 PM   #29 (permalink)
Main Motorcycle: 2010 Bonneville SE Black
echoraven's Avatar
Other Motorcycle: 2011 Rocket III Touring
Originally Posted by luckyduck View Post
I don't deny the good experiences that many of you have had with this oil in your bikes, but for my '01 Bonnie, Rotella T6 has not been a winner.
My shifting quality has become tougher and notchier with the Rotella over the Mobil synthetic that was in it before.
It's cheap and it works, but the fact is is that it doesn't work well for MY bike.
I will be switching back to Mobil 1 v-twin synthetic or trying Motul 5100 in 2000 miles. I might even try draining a quart or so of the Rotella and throwing in a quart of the Mobil or Motul to see if that helps.
YMMV
I had the exact same experience when I used this oil with a Suzuki Katana I had. Since then I stay away from Rotella.
...exposing Forchetto's real identity since 2011...
echoraven is offline   Reply With Quote
Old 11-14-2012, 03:05 PM   #30 (permalink)
mikeinva's Avatar
.You ever been inside both bikes and measured any thing? I think you will find most of the clearances are very close to each other.Ever had your tiger on the dyno.Will you bet money it will out pull my old tractor motor bonnie?
Anybody using Rotella T6 robertrichhart Thunderbird Twin - Technical Talk 8 10-09-2012 01:48 PM
rotella t6 oil warped929RR Speed Triple Forum 21 07-08-2012 02:25 AM
Rotella T and my Bonnie..... kliff Twins Talk 7 03-20-2007 11:55 PM
Thumbs Up..or..Thumbs Down; Need Feedback Shorty Twins Technical Talk 13 07-14-2006 08:01 AM
Rotella 5-40T synthetic Ramsey1200 Trophy 24 04-12-2005 05:58 PM
