This thread is important for more than just the chance to toss around some alternative solutions to securing the relays.
I was lucky enough to get pointed in the direction of a relay full of water as the culprit when my starter was kicking on when the ignition key was turned on. Considering the cost of replacing a burned up starter- or worse- it's a good idea to make sure the relay is secured in a vertical, i e prongs down, orientation.
