Battery tender - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-11-2012, 05:19 PM   #1 (permalink)
Main Motorcycle: 2002 Bonneville
Battery tender
I'll be storing my Bonneville next week, and I'll remove the battery. I have a battery tender that states can be used to charge/maintain two batteries hooked up parallel. I want to do this between the Bonnie battery and my boat battery, which is about 550 CA. Is it reasonable to parallel these two batteries?
mc-bsa is offline   Reply With Quote
Old 11-12-2012, 12:22 PM   #2 (permalink)
Main Motorcycle: rotates daily
ItsForrest's Avatar
Other Motorcycle: Aprilia Scarabeo 500ie
I would not. A motorcycle battery and a deep-cycle boat battery are very different beasts and should have different types of tenders. The boat battery should have something around a 5 amp charger and the motorcycle battery should have 1.25 amp or less and might be cooked by the bigger tender. Hooked up in parallel I would be afraid that either one would be cooked or one would not get sufficient current.
The urge to buy terrorizes.
'08 Scrambler - work in progress...
ItsForrest is offline   Reply With Quote
Old 11-12-2012, 01:48 PM   #3 (permalink)
I wouldn't even consider it.
Marty
Re Battery tender ? thruxton09 Maintenance & Workshop Talk 9 03-29-2012 05:56 PM
Battery tender kills battery? oldretrorider Twins Talk 18 03-12-2010 12:46 PM
Installing the Battery Tender lead to the battery msrtex Twins Technical Talk 4 01-13-2010 09:04 AM
Battery dead - Battery Tender flashing red BerkBon Twins Technical Talk 9 10-30-2009 05:33 PM
battery tender OR battery tender junior? dml955i Speed Triple Forum 4 11-03-2006 08:12 PM
