AI removal kits - rubber vacuum caps - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-20-2012, 03:02 AM   #11 (permalink)
Main Motorcycle: rotates daily
ItsForrest's Avatar
Other Motorcycle: Aprilia Scarabeo 500ie
It wasn't too hard to remove the evap stuff. Unfortunately I did not take photos but I see yours is injected, not a carbie so I don't know how much different that is.
As far as the tank vent, I just disconnected it from the carbon can underneath and left it hanging right where it was. I also left the upper carb vent hanging in the same manner. All the other bits just got yanked and vacuum ports capped.
Between the AI and the EVAP stuff, a good amount of hoses and valves went away.
The urge to buy terrorizes.
'08 Scrambler - work in progress...
ItsForrest is offline   Reply With Quote
Old 11-20-2012, 07:29 PM   #12 (permalink)
Main Motorcycle: 2012 Scrambler
tvscum's Avatar
cool... thanks!
Current: 2012 Scrambler, Bitubo forks, YSS shocks, Arrow 2-to-1, 33mm DB killer, TTP tune #4, Breathe, DNA filter; O2, AI, Airbox baffle, EVAP removed, Up-N-Over, Pivot Pegs, Ventura rack.
Past: '83 Honda XR500; '84 Honda XL600; '86 Yamaha XT350
tvscum is offline   Reply With Quote
Old 11-21-2012, 01:57 AM   #13 (permalink)
Main Motorcycle: Triumph Thruxton
Shospeedmaster's Avatar
Other Motorcycle: Triumph Speedmaster
What is the benefit by removing the AI? Would it make the bike hard to start during a cold morning?
Shospeedmaster is offline   Reply With Quote
Old 11-21-2012, 09:10 AM   #14 (permalink)
Main Motorcycle: 2012 mag wheel Bonnie
RSDA's Avatar
biker7 describes the benefits here:
http://www.triumphrat.net/twins-tech...ml#post1296473
2012 Bonneville. Modifications.
RSDA is offline   Reply With Quote
an exciting question about vacuum caps f64 Twins Talk 35 10-06-2012 10:43 AM
Vacuum caps wrong size. TJohn Twins Technical Talk 2 11-06-2011 12:57 AM
Carb vacuum caps GJT Cruisers - America, Speedmaster 6 12-19-2010 11:33 PM
Carb Vacuum Caps kj4nt Twins Technical Talk 4 04-29-2007 08:13 PM
rubber caps? 97TB Speed Triple Forum 3 06-15-2005 09:56 PM
