2005 Bonnie Speedometer reads 10% high - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-11-2012, 09:25 AM   #1 (permalink)
Main Motorcycle: 2005 Bonneville
SevenMonkeys's Avatar
I got a 2005 Bonnie two years ago and the speedo has read about 10% high since I got it.
Is there a simple way to adjust the speedo?
Casey
SevenMonkeys is offline   Reply With Quote
Old 11-11-2012, 10:51 AM   #2 (permalink)
Casey
Since there are no "easy adjustments, the two ways to easily deal with it is to either get a front tire that has a larger overall diameter (they're not all the same, even if they have the same size designation) such as a Metzler ME880 (great tire btw). Or you can source a Thruxton speedometer drive from a MC salvage yard such as Pinwall. They are set up for an 18" wheel and that will correct things by turning less rpms per mile...
I run ME880 fronts, stock size and they give me just about dead on readings when I go past those "you speed is" radar stations...
SCbonneville is offline   Reply With Quote
Old 11-11-2012, 11:07 AM   #3 (permalink)
Main Motorcycle: duh
bheezy27403's Avatar
Other Motorcycle: old mini bike
I bet it's flashing red when it tells you your speed ;}
bheezy27403 is offline   Reply With Quote
Old 11-11-2012, 07:20 PM   #4 (permalink)
Main Motorcycle: 04 cafed Bonnie
ozbon's Avatar
Location: Toowoomba Queensland Australia (soggy bottom)
Extra Motorcycle: Two '68 Benelli 350's
Casey
Yeah!!, Ride 10% slower!!!.......
"Yeah, look.....Baz just vanished, like a.....fart in a fan factory, ya`know?! ".
Daz, the cane toad.
ozbon is offline   Reply With Quote
Old 11-11-2012, 09:28 PM   #5 (permalink)
I put a Metzler on the rear, but the BattleAx in front hasn't needed replacing. I'll probably put a Metzler up front when the time comes.
Thanks.
Old 11-11-2012, 10:55 PM   #6 (permalink)
Main Motorcycle: '06 Speed Triple
Other Motorcycle: '96 Adventurer Cafe Racer
Extra Motorcycle: Not any more
Not having a Bonnie myself, is the speedo mechanical or electronic? If it's electronic, a speedo healer should do the trick.
Don
'06 Speed Triple
and a bunch of other stuff
If everything seems under control, you're just not going fast enough - Mario Andretti
zelatore is offline   Reply With Quote
Old 11-12-2012, 09:08 AM   #7 (permalink)
Mechanical up to 2009 or thereabouts.
Marty
Old 11-12-2012, 09:21 AM   #8 (permalink)
Main Motorcycle: Bonneville
Other Motorcycle: Vespa PX200
Extra Motorcycle: Kawasaki GTR and Sidecar
Hello
UK law (and probably elsewhere) allows for a 10% speedo error (reading high) to allow for different tyre sizes and wear and bragging rights or use a sat nav.
Regards
Barry
threewheelsuk is offline   Reply With Quote
Old 11-12-2012, 09:34 AM   #9 (permalink)
Main Motorcycle: '06 T100
Bron-Yr-Aur's Avatar
Other Motorcycle: Kawasaki KXdirtshredder
Extra Motorcycle: '76 Tiger 750
You can't even really trust the nav systems either. My Garmin reads up to 4 mph off sometimes. It also varies depending on if you're on flat land or in the hills. Long story short, are you sure the readings are off?
I thought that my '06 was off 4-5 mph, but after doing my own calculations, I realized with my stock tire, at 60 mph it was only 1-2 mph wrong.
Bron-Yr-Aur Garage
Last edited by Bron-Yr-Aur; 11-12-2012 at 10:28 AM. Reason: Don't konw hwo to tpye
Bron-Yr-Aur is online now   Reply With Quote
Old 11-13-2012, 09:50 AM   #10 (permalink)
I knew it was not correct just based on what traffic around me was doing. I'd be doing 15 over in a 45 zone and still getting passed :-)
So I used a simple speedo app for Android on a long straight stretch and held a steady speed.
The speed given by GPS is pretty accurate if held steady for say ten seconds. It has to smooth your velocity a bit as it calculates it. It could be off by couple percent, but not ten.
I'm used to the speed being off, but I hate that the odometer has the same error. And all my mpg calculations have a fudge factor.
Pick-up coil reads too high jonathanrsr Hinckley Classic Triples 8 08-23-2010 11:19 PM
Speedo Reads High Mozart 2 T3 Sport / Touring Forum 13 08-05-2010 01:18 AM
Rev Counter reads high Bixxer Bob Tiger Workshop (archive) 13 08-15-2009 09:34 AM
Speedometer reads Zero DaytonaRider Daytona Deliberations 11 03-14-2008 12:10 PM
'02 Speedometer reads 10% fast stephenjpauls Daytona Deliberations 6 10-08-2007 12:02 PM
