Mixture issues. Backfiring through intake, hard to start - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
post #11 of 16 (permalink) Old 11-12-2012, 01:55 AM Thread Starter
Haha, my conditions aren't all that cold. Today it was about 50-60 degrees F all day.
luckyduck is offline
post #12 of 16 (permalink) Old 11-12-2012, 07:03 AM
Ok. You've probably got a vaccum leak which will also cause the decel popping you're getting.
denbow is offline
post #13 of 16 (permalink) Old 11-12-2012, 03:13 PM Thread Starter
Found at least one area of leakage. I pulled both inlet manifolds today to take a look at the single o-ring that seals them. The left side manifold's o-ring was intact. The right side manifold's o-ring was degraded, about 1/4 of it was completely missing (must have been sucked into the engine or something!).
Anyways, so I put everything back together but I'm not going to ride until I can replace the o-rings and the rubber boots. I was thinking I could simply squirt in a bit of silicone sealant in the groove for the o-ring but I decided against it ultimately.
Thanks for all the help!
post #14 of 16 (permalink) Old 02-26-2013, 09:41 PM
Main Motorcycle: 08' Bonnie
08Bonnie's Avatar
Lucky Duck,
Did you ever fix the carb spit back issue you were having? Mine is doing the same thing and wont even run unless i have the choke all the way out. I'd be interested to know how yours turned out.
Various stuff...
08Bonnie is offline
post #15 of 16 (permalink) Old 02-27-2013, 01:44 AM Thread Starter
Yes I did solve the spitback by merely turning the mixture screws out 3 turns on 40-size and 2.5 turns on 42-size. The adjustment of the mixture screws will be specific to your bike, but they really make the most difference when it comes to idle and just-of-idle performance.
I do get spitbacks (or coughs) sometimes, still, and it's usually when the engine is cold. Thus, I believe the problem is caused by an overabundance of air and too little fuel when the butterfly valve is closed to just immediately cracked open.
post #16 of 16 (permalink) Old 02-27-2013, 11:35 PM
08Bonnie's Avatar
My bike has been running really poorly lately. Massive amounts of 'spitback' at low rpm, kept knocking the airfilters off their mounts. More than a few times i thought to myself the carbs would have to be completely overhauled, fortunately i was wrong. I found the culprit to be a clogged pilot jets. I had put off checking the pilots since I dont know of any good way to take them out without taking the carbs off of the bike, a pita in my opinion. Well not so much taking them off but I dare someone here to tell me it's easy putting the throttle cables back on, my fingers are still bleeding. Anyway, once on my bench i was able to see that the pilots were solidly blocked. A little carb spray and a very thin needle and all was good. Put it back together, fired up and runs like new. Man, the things I learn messing with this bike.
Various stuff...
08Bonnie is offline
2nd gear hard shifting issues on 99 speed triple deflorence Speed Triple Forum 4 11-02-2011 12:36 PM
Backfiring issues johnshumpert Twins Technical Talk 6 07-13-2010 01:25 PM
Electrical issues Hard start and Speedo SpeedTona Daytona Deliberations 4 05-16-2010 11:19 PM
Backfiring and stalling after red-lining or riding hard sasper Twins Technical Talk 10 04-23-2010 08:08 PM
hard bag panels - color match issues? huc Sprint Forum 12 08-09-2005 04:00 PM
