Help - My Thruxton is dead! - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
post #11 of 45 (permalink) Old 11-09-2012, 02:50 PM
Main Motorcycle: Triumph Thruxton EFi
Other Motorcycle: Yamaha R1, Honda CB1000R
Originally Posted by timpee77 View Post
Guy's advice is spot on.
Check you don't have a spark by pulling both the plugs, grounding one of them and turning it over. If you don't have spark then do as stated above. If you don't have a mate with a similar bike you'll need to start testing and replacing bits but its really likely it'll be pickup coil, located under the clutch side cover or the coil which is tucked up under the front of your tank. In the case that its your CDI then you're better off getting an aftermarket one from ProCom than paying the crazy prices that triumph want for new genuine one.
I had a similar prob with my ’05 T100 and it ended up being the pickup coil.
I don't think that works unless you ground both plugs, I can't remember the exact expaination for this but Forchetto discussed it way back and it made sense.
GDCobra is offline
post #12 of 45 (permalink) Old 11-09-2012, 03:13 PM
Forchetto's Avatar
On the 360º engines the coil secondary is double-ended and "floating". Neither end is connected to ground. It's called a "wasted spark" system.
The voltage leaves one secondary coil terminal, jumps the first plug gap then travels through the metal of the cylinder head, jumps the gap on the other plug and returns to the remaining coil terminal.
Don't operate the ignition system unless both plugs are grounded, you can burn out the coil windings like that.
Forchetto is online now
post #13 of 45 (permalink) Old 11-09-2012, 04:03 PM
Main Motorcycle: 2014 Scrambler
bluesforchallah's Avatar
I know it can't be the pick up coil as my dealer stated to me "they very rarely ever go bad".
2014 Scrambler: Arrow 2-1 high pipe. TTP Tune 4 with Breathe airbox cover no baffle.
Past rides:2008 T100, 1975 Honda CB400/4, 1989 Honda GB500, 1965 Honda CB450 Black Bomber, 1972 BSA A75 Rocket3
bluesforchallah is online now
post #14 of 45 (permalink) Old 11-09-2012, 04:31 PM
Forchetto's Avatar
My wife's Peugeot has got through four ignition coil packs so far. The Net is full of Peugeot forums moaning about the problem and yet three different main dealers reckon they've never heard of the problem...wankers.
The funny thing is that all of them have the things in stock for immediate delivery and fitting...my question as to why they should have readily available spares for a part that never fails draws vacant looks from the brain-dead oafs.
post #15 of 45 (permalink) Old 11-09-2012, 07:56 PM
Main Motorcycle: Thruxton
Gary_spain's Avatar
Other Motorcycle: Rieju Tango
If it does turn out to be the coil here's a source for a reasonably priced replacement:
http://www.motobins.co.uk/displayfin...?q=70506&go=GO
07 Thruxton: TEC 2 into 1, K&N, TTP Breathe Bellmouth, 135 mains, 40 pilots, std. needles, 1 shim (0.65mm). All baffles removed. Bitubo Fork Cartridges. Bitubo Rear Shocks. TEC Steering Damper. 3 Pot Nissin (Honda) brake caliper.
Gary_spain is offline
post #16 of 45 (permalink) Old 11-10-2012, 08:51 AM Thread Starter
Other Motorcycle: Vespa 125 Primavera ET3
Thanks, everyone. I have a friend coming over today with a meter and we'll see what we can find out.
The igniter looks fine with no witness marks on that or the seat.
The battery is out being charged. What's the betting it starts right up when I put it back?
It's cold today, whereas when it broke down the engine was hot from being stuck in traffic.
The pick-up coil - I had a look at the service manual, and it looks like I need to drain the oil and take off the right-hand side engine cover, yes? In which case it'll have to be done by a garage as I don't have the disposal facilities.
Londonbabe is offline
post #17 of 45 (permalink) Old 11-10-2012, 09:30 AM
Originally Posted by Londonbabe View Post
... it looks like I need to drain the oil and take off the right-hand side engine cover, yes? In which case it'll have to be done by a garage as I don't have the disposal facilities.
I don't think you have to drain the oil to open up the RHS of the engine, if the bike is on the side stand the oil all runs over to the clutch side, you probably will need a new gasket though and some sealer for where the wire and gromet runs throgh the case.
GDCobra is offline
post #18 of 45 (permalink) Old 11-10-2012, 04:16 PM
Main Motorcycle: 2012 bonneville T100
Choprocker's Avatar
where abouts in london are you?
there is a place called the oval motorcycle centre it off workshop space tools and advice to do your own servicing with guidance from there technicians.
http://www.ovalmotorcyclecentre.co.uk/web/index.php
Choprocker is offline
post #19 of 45 (permalink) Old 11-10-2012, 06:42 PM Thread Starter
Wow, never heard about that place before. That sounds cool.
Now then, should I buy a Moto Guzzi v7 Special? They are on interest free credit at the moment, and do look nice.
post #20 of 45 (permalink) Old 11-10-2012, 11:39 PM
Main Motorcycle: thruxton
Triumphs are so much sexier than Moto Guzzis!
tsx123 is offline
need some help with dead thruxton RacerX113 Twins Technical Talk 19 11-25-2010 09:58 AM
Issue with dead Thruxton Treehugger Club Cafe' 21 05-16-2010 12:41 AM
Thruxton Turn Signals Dead :( Neil Walters Twins Technical Talk 11 01-08-2009 10:15 PM
Thruxton Dead kaligrown Maintenance & Workshop Talk 3 10-31-2008 11:33 AM
Dead Thruxton bryancald Club Cafe' 10 01-06-2006 08:29 AM
