Carbon fiber gas tank? - Page 3 - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-12-2012, 01:16 AM   #21 (permalink)
Main Motorcycle: '09 Triumph Thruxton
Burgandy25's Avatar
Other Motorcycle: 1978 schwinn le tour
Your right but I don't think im gonna go this route anymore, for a racebike it might be worthit to save weight but since my bike is for road commuting id rather had a tank that can "give" God forbit if anything does happen like of I get hit or go down, or if some knuklehead knocks by bike over while its parked; I dont want a fuel tank that will crack and leak fuel all over the engine and bodywork tgat doesnt need it. so imma stick with the stock tank, get a lighter battery and be happy :-)
Sent from my SCH-I510 using Motorcycle.com Free App
Burgandy25 is online now   Reply With Quote
Old 11-15-2012, 11:57 AM   #22 (permalink)
Main Motorcycle: "Hamilton"
GySchmit's Avatar
Other Motorcycle: Kawaski KX105 (85 Bored)
If you still want the carbon fiber look don't forget the hydrographics carbon fiber film dip option.
Schmit
GySgt, USMC(Ret)
__________________________________________________ _______________________
"Hamilton" - 2005 Thruxton
GySchmit is online now   Reply With Quote
Old 11-15-2012, 10:22 PM   #23 (permalink)
Main Motorcycle: 2006 Thruxton CaspianBlue
Other Motorcycle: HDtouring Hondaoffroad MX
Extra Motorcycle: YES...
Speaking of carbon fiber I seriously day dream about building a STOCK looking frame out of carbon fiber and a lot of other bits and pieces for the Bonneville/Thruxton. These bikes need to loose about 100 pounds...I know it would not work for the engine, head and center cases, but side cases, frame, wheels and such might be worth the effort in CF. I will work on this next summer and see how it goes and how much weight can be lost with out loosing too much $$.
Von Dutch is offline   Reply With Quote
Old 11-15-2012, 10:26 PM   #24 (permalink)
Main Motorcycle: -
Joining the carbon fiber tubing will give you all kinds of hell, and cost a fortune. If you are willing to put up with that, I’ll love to watch.
Stanislao is offline   Reply With Quote
Old 11-16-2012, 04:27 AM   #25 (permalink)
Main Motorcycle: 2009 speed triple
That's pretty interesting considering th Bonnie is so old school but has some super modern touches.. Maybe don't go so far as to put a gp exhaust maybe??
bbmakmak is offline   Reply With Quote
Old 11-16-2012, 01:36 PM   #26 (permalink)
Main Motorcycle: 2012 T100
norton74's Avatar
Other Motorcycle: 2013 Rocket 3 Touring
Extra Motorcycle: '73 Ducati GT750
I replaced a fiberglass tank on my 73 ducati that had started to soften in spots. I cut out the soft spots, filled the old tank with urethane foam and then finished with fiberglass and epoxy resin to get my plug mold. I then made two female molds from the plug, a top and a bottom.
I then used a fiberglass veil for the surface next to the mold and then coarse yarn carbon fiber cloth with West Systems epoxy resin to make the upper and lower pieces of the tank. I used a vacuum pump and bag to create the consolidation pressure that I needed.
At this point I simply epoxied in the hardware necessary for the fuel cap, attach points, and fuel petcocks. I then glued the upper and lower pieces together with filled epoxy adhesive, trimmed, and then used POR15 tank sealing system. At that point, it was time to paint.
Turned out great. Lots of work and a certain amount of expense. However, I wasn't able to find a replacement tank; so, it became a DIY project.
norton74 is offline   Reply With Quote
Triumph Carbon Fiber Tank Pad sincity337 Sprint Forum 20 01-14-2013 11:45 AM
3/4 length carbon fiber tank cover!!!! dphex T3 Sport / Touring Forum 11 01-28-2009 03:52 AM
carbon fiber half tank cover Justice Strike Triumph SuperSports 9 12-15-2008 08:02 PM
Carbon Fiber Gas Tank MattTriumphs Twins Technical Talk 30 05-28-2008 11:40 PM
Triumph Carbon Fiber Tank Protector motomyth Sprint Forum 6 07-15-2006 02:55 AM
