T100 Oil light came on during warm up - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.comMotorcycle.com Classifieds!SportbikeTrackGear
Old 11-05-2012, 07:34 PM   #1 (permalink)
Main Motorcycle: Steve Mcqueen T100
Hi everyone,
I am riding a new T100 (McQ) and while warming it up yesterday the engine shut off and the red oil pressure light came on.
Should I be worried?
Thanks,
Frank
Archon is offline   Reply With Quote
Old 11-05-2012, 08:29 PM   #2 (permalink)
Main Motorcycle: Bonneville
If the engine stalled before the oil light came on then I would say don't worry. No run, no oil pump, no pressure, light comes on. As to why it stalled, dunno, can happen on warm up. Depends on your technique.
JustPete is offline   Reply With Quote
Old 11-05-2012, 09:00 PM   #3 (permalink)
Main Motorcycle: 2010 Thruxton
artful bodger's Avatar
Other Motorcycle: 1942 BSA
Agreed. If the light came on after the engine turned off all is normal. Check level and try again and use the "choke" for longer so it doesn't stall. If it came on before it stalled I would look have it looked at for something more serious.
Good luck.
Alastair.
artful bodger is online now   Reply With Quote
Old 11-06-2012, 12:19 AM   #4 (permalink)
Legend
Forchetto's Avatar
See your handbook concerning starting procedures, there are one or two subtleties peculiar to these bikes:
• If the engine is cold, pull out the choke, noting the following: Above 25°C air temperature, pull out the choke to the first position. Below 25°C air temperature, pull out the
choke fully.
If the engine is partly warm, pull out the choke to the first position.
• Leaving the throttle completely closed, push the starter button until the engine starts.
Old 11-06-2012, 12:50 AM   #5 (permalink)
Main Motorcycle: Black Thruxton 08
Other Motorcycle: WhiteTiger Sport 13
Note also the wierd affect washing the bike can have. The rubber boot that covers the oil pressure switch usually traps water which then can cause a short that activates the light, even though normal oil pressure is present. Solution pull the boot back use some DWF and wipe off, then the switch should operate properly. That is a common enough issue with the oil pressure light.
If the motor cut out while idling then the light should come on, as discussed in the other posts. If the light came on before the motor stalled then maybe the issue above, or something else. Take care here. It is rare that something catastrophic might be happening but it can happen.
Cheers, Simmo
Ride it while you can.
Simmo is online now   Reply With Quote
Old 11-06-2012, 03:57 AM   #6 (permalink)
Thanks for the help. To clarify, I gave a bit of throttle and the engine shut off, then the light came on. The light was not on while the engine was running. I'm guessing that's normal and nothing to worry about from you all.
Old 11-06-2012, 04:52 AM   #7 (permalink)
Main Motorcycle: Bonnie T 100
Crackon's Avatar
In four years l've never used the "choke". Riding daily all year round.
Should l be worried?
Don't tell me, l don't care.
Crackon is online now   Reply With Quote
Old 11-06-2012, 07:34 AM   #8 (permalink)
Yes, the oil light should be on when the engine's not running because there's no oil pressure.
If it comes on when the engine's running, you either have a malfunctioning sensor or a big problem, and should shut down the engine immediately.
Marty
T100: MIL Light - OBD Code P0118 VoxExMachina Twins Technical Talk 12 05-22-2012 02:17 PM
T100 oil pressure light? Santalum Twins Talk 12 03-18-2011 11:32 PM
low oil light at ilde when warm! fizzer09 Maintenance & Workshop Talk 7 05-09-2009 06:53 PM
Speedo light on 2008 T100?? apprentice Twins Technical Talk 3 03-25-2009 09:24 PM
2nd day of T100 made a warm up mistake! rays323929 Twins Talk 17 05-04-2006 05:27 PM
