11-04-2012, 05:16 PM
Site Supporter SuperStock Main Motorcycle: BMW R1200RT
Posts: 210 Other Motorcycle: 2002 T100 Centennial
Looking for a 7 convex headlight reflector
Hello,
I have a 2002 T100 Centennial.
In an effort to make it look more retro I would like to change from a flat headlight lens/reflector to a convex one.
I drive on the right hand side of the road (Canada) and my current OEM headlight has a parking light in it.
Has anyone done a swap before and if so what did you use?
11-04-2012, 08:52 PM
Grand Prix 500 Main Motorcycle: Bonneville
Posts: 125 Other Motorcycle: Honda Postie Extra Motorcycle: Suzuki DL650 V Strom
Hello
Including freight that is just under $44. Very good price, I paid $100 for a Hella here in Australia. I wonder what quality they are, probably ok. Country of manufacture? Does not matter these days, as long as quality is ok.
11-04-2012, 09:40 PM
Grand Prix 250 Main Motorcycle: Bonneville T-100
Posts: 65 Other Motorcycle: HONDA 550 CBK 1977 mod
Just put on a Cibie from Daniel Stern, with an Osram bulb, (65/70 W). Better light in the dark. Maybe will try an even larger bulb next ? I also revired with 10 gauge wire and relays direct from battery for 1 volt more at hte headlight. See 'how to' by Ecosse at this forum. It is well worth it for about $50 for the wiring job.
Norse
11-05-2012, 07:51 AM
I put in a Lucas repop from Emgo years ago. I recall having to get a new halogen bulb that converted over to the newer 3-prong connector (H4?). There was a parking lamp bulb too.
I discovered that a stock headlight rim (ring) from the America or Speedmaster will fit a standard/T100/Thruxton headlight shell (bucket). There are noticeable differences however. Externally, the rim tucks-in tighter to the lamp edge almost eliminating the air gap between the two. There is no external lamp alignment screw (or alignment mechanism) and maybe it's an optical illusion, but the cruiser rim seems to be slightly deeper with a less rounded profile.
Internally... and relevant to this thread... the lamp mounting system is completely different. Whereas the Std/T100/Thruxton rim has an inner lamp mounting plate with various alignment hardware, the cruiser rims use a single formed wire "clip" that snaps-in a groove and pinches the lamp to the rim. I think this latter rim style will make fitting a new non-OEM lamp much easier.
I suspect the lack of the horizontal alignment feature is because the cruiser headlights are bottom mounted negating the need for internal adjustment.
/M
"With integrity, nothing else matters. Without integrity, nothing else matters."
11-05-2012, 07:54 AM
Ohhhhh, that's great information and really critical. Thanks so much for posting that.
11-05-2012, 05:17 PM
SuperSport Main Motorcycle: 2003 Triumph T100
Posts: 1,386 Other Motorcycle: 2007 M-G Cali Vintage
You might try looking around the Domi Racer site. They handle a bunch of the original NVT parts (including reproduction parts). I get all my footpeg rubbers and mufflers from there.
https://www.domiracer.com/homepage.html
11-05-2012, 05:33 PM
SuperStock Main Motorcycle: Thruxton
Posts: 273 Other Motorcycle: Rieju Tango
Hella part number 1A6 002.395-071 is a direct replacement. Cost in Europe is about 40 Euros from most any car parts shop.
07 Thruxton: TEC 2 into 1, K&N, TTP Breathe Bellmouth, 135 mains, 40 pilots, std. needles, 1 shim (0.65mm). All baffles removed. Bitubo Fork Cartridges. Bitubo Rear Shocks. TEC Steering Damper. 3 Pot Nissin (Honda) brake caliper.
11-05-2012, 05:41 PM
I think the Hella is a flat lens. I am looking for convex.
I found 2 places that have the Cibies. One wants $90. each and the other wants $45. for a pair. Just waiting to hear back from the $45. place to see if they are the right ones and have a parking light.
11-05-2012, 11:50 PM
World SuperBike Main Motorcycle: 04 cafed Bonnie
Location: Toowoomba Queensland Australia (soggy bottom)
Posts: 1,861 Extra Motorcycle: Two '68 Benelli 350's
I put one of these on my bike, perfect fit, low/high beam. no parking light.
link
http://www.ebay.com.au/itm/NRG-SB701...#ht_1996wt_906
"Yeah, look.....Baz just vanished, like a.....fart in a fan factory, ya`know?! ".
Daz, the cane toad.
