Warning lights not working - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 18 (permalink) Old 11-04-2012, 04:04 PM Thread Starter
Main Motorcycle: EFI Thruxton
thruxton09's Avatar
Other Motorcycle: GS 850 Suzuki
My ecu & low fuel lights dont come on at all. Its an 08 Thruxton .
The bike starts & runs fine ,All other electrics are working , Just no warning lights . I've checked the fuse;s & the connections in the headlight shell, is there something I'm missing ?
can someone help here please, I'm a bit concerned about riding with out the ecu light .
thruxton09 is offline
post #2 of 18 (permalink) Old 11-05-2012, 04:20 AM
DEcosse's Avatar
Do your parking lights come on with key-switch in 'ON' position?
Do they come on in 'Park'?
Is your instrument back-light on with Ignition 'On'?
If they do not come on in any circumstances, check Fuse 8
If you do not have park lights but Fuse 8 is good, (or they come on in 'Par'k but not 'On')you need to check ignition switch for broken contact
If park/instrument back-lights are on, check for 12V at the Red/Blue connector to the LED connector.
DEcosse is online now
post #3 of 18 (permalink) Old 11-05-2012, 06:36 AM Thread Starter
thruxton09's Avatar
All lights are working but no power to the led's , so whats the next step ? . Thanks for your reply DEcosse .
post #4 of 18 (permalink) Old 11-05-2012, 10:42 AM
Forchetto's Avatar
Been looking at the circuit diagram but can't make anything of it. All the wiring to the instruments is shown as piling into a square box numbered "1", no details of where the wires go.
This is a link to it in case anyone else is willing to have a go:
http://www.telecable.es/personales/a...%20diagram.jpg
The chances of both LEDs failing at the same time is remote. So is the possibility of the connections to the ECU failing at the same time. I guess it has to be whatever common connection the two LEDs have, like a an earth or ground connection within the instruments, I think they're coloured black. Check them all for soundness, both behind the instruments and in the connector within the headlight shell, initially you could turn on the ignition and waggle things about while observing the LEDs, any flickering points out a bad connection.
Forchetto is online now
post #5 of 18 (permalink) Old 11-05-2012, 08:20 PM
Main Motorcycle: Bonneville
Pin 9 on the cluster appears to be the wire controlling the MIL and low fuel. It's most likely multiplexed so you can check the integrity of the wire itself (red wire) but not much else.
Would also recommend you scan for codes. This might be your best bet to finding the reason why.
JustPete is offline
post #6 of 18 (permalink) Old 11-06-2012, 01:52 AM
DEcosse's Avatar
The LEDs are not part of module 1, the instruments - LEDs are module 57
post #7 of 18 (permalink) Old 11-06-2012, 02:02 AM
Forchetto's Avatar
Oh yes, thanks. Never noticed that, I was expecting the diagram to place such things more or less close to their final position.
post #8 of 18 (permalink) Old 11-06-2012, 02:13 AM
DEcosse's Avatar
Agree, kind of odd location in the schematic
post #9 of 18 (permalink) Old 11-06-2012, 07:29 AM
Good eye, that changes things. Thruxton09, disregard my ramblings.
JustPete is offline
post #10 of 18 (permalink) Old 11-06-2012, 04:04 PM Thread Starter
thruxton09's Avatar
Thanks for your help guy's ,I think I will get the dealer to try & sort it out. The bike is due for its 30,000 service so I hope i nothing goes wrong when I ride it the 180 klms over there for it. She seems to be going alright apart from those lights .
Warning lights gonfishen Cruisers - America, Speedmaster 1 10-31-2012 03:17 AM
Some idiot lights not working thrasherdave Twins Technical Talk 3 05-04-2011 01:55 AM
Warning lights Caulky Classic, Vintage & Veteran 9 11-22-2010 06:46 AM
Warning Lights mynock03 Hinckley Classic Triples 8 05-17-2009 02:49 PM
getting both lights working eagle Tiger Chat 9 03-04-2004 07:33 AM
