Basic servicing - fuel filter? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-04-2012, 07:47 AM   #1 (permalink)
Main Motorcycle: 2008 Bonneville
I'm racking up the miles (kms) on my bonneville and am going to be doing my first service pretty soon. I'm looking at ordering the parts from the UK (way cheaper than Aus). I found some basic service part kits. 1 of which include a fuel filter - does a Bonneville have a removable filter? My last bike had a filter but it wasn't removable, although could be dismantled to be cleaned...
Mr*Beaver is offline   Reply With Quote
Old 11-04-2012, 08:05 AM   #2 (permalink)
Main Motorcycle: 2010 Bonneville T100
Other Motorcycle: 2007 150cc Retro-scooter
Filter is a spin-on on the bottom of the engine.
There is a fine line between "hobby", and "mental illness"
Owenbrau is offline   Reply With Quote
Old 11-04-2012, 08:41 AM   #3 (permalink)
Legend
Forchetto's Avatar
Is it carbed or EFI?. I guess it might be carbed in which case there are no fuel filters as such, just a couple of fuel strainers, one built-in in the gas petcock and another inside the "T" piece that splits the fuel feed to the carbs.
The petcock strainers are the yellow/white bits at the end of the delivery pipes in the left hand petcock:
This is the location of the "T" piece strainer:
If it's an EFI bike there are plenty of threads with details of the in-line fuel filter inside the tank on threads as this:
http://www.triumphrat.net/twins-tech...el-filter.html
http://www.triumphrat.net/twins-tech...ge-or-not.html
Old 11-04-2012, 05:39 PM   #4 (permalink)
Main Motorcycle: 2007 T-100
Other Motorcycle: XS 650 on going project
filter
The spin on filter at the bottom of the engine is the oil filter.
tshadow6 is offline   Reply With Quote
Old 11-05-2012, 02:45 AM   #5 (permalink)
thanks Forchetto - spot on what I was looking at.
@ the rest - you'd hope I know what the oil filter looked if I was planning on doing any kind of service ha ha
Old 11-05-2012, 09:05 AM   #6 (permalink)
oops, I misread, thought he meant oil.
Sent from my iPad using Motorcycle
Old 11-07-2012, 07:51 PM   #7 (permalink)
Main Motorcycle: 2012 base bonneville
Extra Motorcycle: 2006 XL1200L
another PLUS for the carb'd guys!!!
rodhotter is offline   Reply With Quote
Old 11-08-2012, 07:10 AM   #8 (permalink)
EFI fuel filter option
If your bike is EFI then the Mahle KL145 filter available through BMW outlets in OZ is identical and cheaper. I just did my first fuel filter change. Get a new rubber 'tank access plate' gasket just in case you need to replace the old gasket. I reused my old gasket but I like to be prepared.
BTW Bike Bandit in the USA now stocks OEM triumph parts much cheaper than here and they just had a 25% discount sale on OEM parts. They ship here reasonably cheaply too. Maybe worth comparing with UK prices.
Cheers, Richard
'09 America
Dunamis is offline   Reply With Quote
Old 11-08-2012, 06:20 PM   #9 (permalink)
richm's Avatar
Hardly - at 12k mile intervals, it's not that big of a deal.
richm is offline   Reply With Quote
Basic Modification; AI removal, UNI filter, Snorkel, rejet. MrTwistie Twins Technical Talk 6 05-19-2012 02:03 AM
Servicing the "Non-Servicable" Fuel Petcock Mr Bentwrench Maintenance Tips and Tricks for the T3 Classics 2 12-20-2011 09:06 PM
EFI Bonneville Air Filter and Fuel Filter Sparky Twins Technical Talk 6 02-07-2011 11:58 AM
Fuel Filter/oil filter/oil type Anchorbend Twins Talk 4 07-24-2005 01:00 AM
