Larger Sport Tire Recommendations for Stock T100 Rims? - Triumph Forum: Triumph Rat Motorcycle Forums
Old 10-29-2012, 04:06 PM   #1 (permalink)
Main Motorcycle: 2011Bonneville T100
My 2011 T100 is currently stock and I'd like to get some better tires that I can grow into. I've read enough of the tire threads here to know that what's offered in stock sizing is limited but that I can go up on size and have a much better selection of more sport-oriented tires. Beyond that I get confused at some of the mix-and-match solutions I've read about and would think there should be a matched set of great sport tires that can be accommodated by the stock rims.
Stock setup specs on the current tires:
Front- 100 / 90-19 M/C 57H; Rear- 130 / 80 R 17 M/C 65H
Front Wheel- 36-spoke, 19 x 2.5in.; Rear Wheel- 40-spoke, 17 x 3.5in.
What sizes can I look at to get a matched set of better tires using these same rims? Thanks.
( And if I've just missed the master thread where all this is explained, just point me in the right direction. )
All the best,
Hilo
hilobemagical is offline   Reply With Quote
Old 10-30-2012, 10:16 PM   #2 (permalink)
<head scratch>
Did I do something wrong?
</head scratch>
Hlo
Old 10-30-2012, 11:27 PM   #3 (permalink)
Main Motorcycle: 2007 bonnie black
killian101's Avatar
Other Motorcycle: 68 BSA (RIP)
No, not really. The topic has been disused, at times, ad nauseum. Keep your front stock, 140/80 or 90/17 will work just fine. Some folks are moving up to 150...I run 140/80/17 and what ever stock up front it. Sport Demons are a nice choice
killian101 is online now   Reply With Quote
Old 10-31-2012, 12:31 AM   #4 (permalink)
Thank you. Appreciate it.
Hilo
Old 10-31-2012, 04:55 AM   #5 (permalink)
Main Motorcycle: 05 T100
The problem with getting a matched pair of sport oriented (generally radial) tyres for the T100 is the wheel sizes. Not many are available in a 19" for the front and the rear is too narrow for anything over a 140. Although plenty of people use a 150 on the rear, the only 150 I've seen that is actually recommended by the manufacturer for a 3.5" rim is the Dunlop GT501. As Killian said, Sport Demons are a sporty (bias ply) tyre that work well and are available in suitable sizes, but they wear quickly.
Paul.
Herts. UK
Old 10-31-2012, 07:02 AM   #6 (permalink)
Main Motorcycle: 09 Bonnie Black
Other Motorcycle: Tiger 1050
Extra Motorcycle: RE Interceptor
I used to run a 140/80 on the rear but I didn't like the way it made the bike handle. It raised the rear of the bike which seemed to make it "twitchy" in high speed corners. I've since gone back to the stock size and it seems better. Others have used a larger rear tire with success though so your mileage may vary. If I were going with a 140 or 150 on the back I'd drop the sidewall down to a 70 series to keep the overall tire diameter down a bit.
henrys is offline   Reply With Quote
Old 10-31-2012, 09:46 AM   #7 (permalink)
Yes. Exactly the why I posted the original. I really do understand the reason for Killian101's "ad nauseum" comment. As sigh-inducing as another thread on this topic must have been for the long-time members here, it was equally frustrating to read the several dozen threads on the topic (and then go download spec PDFs from manufacturers), and not find a solution. The Michelin Road 3 spec sheet, for example, lists a 110-19 available for the 2-1/2" rim on the front but doesn't offer a 140 for the rear. The Road 2s don't offer a 19" front at all. Well... crap. One of the most-acclaimed brand models in the threads seems unavailable for the T100.
So, another look, and I find the Michelin Pro Activs are available in both sizes for the T100, but now were back to bias-ply instead of radial.
Yes; it is seeming that bias ply is the only option given the T100's sizing limitations. I'll take a look at the SDs.
Originally Posted by henrys View Post
If I were going with a 140... on the back I'd drop the sidewall down to a 70 series to keep the overall tire diameter down a bit.
Henrys, I hadn't considered the height increase on the rear with a 140. Thanks for a very useful rec on the 70 profile.
I appreciate the three of you trying to help with this. Thanks.
All the best,
Hilo
Old 10-31-2012, 07:36 PM   #8 (permalink)
Main Motorcycle: 03 T100
mikeinva's Avatar
One more thing if you go to 140/80 its changes gearing about a 1/2 tooth up front the 140 /80 on stock wheels gives a very round tread on the ground going in a stright line so stright line traction goes down some .I run the 150/70 gt501 on the rear of mine.I like it better then the 140/80 s.d. I had before.
Old 10-31-2012, 07:43 PM   #9 (permalink)
Main Motorcycle: 2012 base bonneville
Extra Motorcycle: 2006 XL1200L
the 140-70 is very close to stock diameter and works on our stock 17" rear rim, be aware of incorrect rim to tire sizing distorts the tread. having bigger rims will open up your choices. on my sportster i used 18x3.5 front allowing use of 120-70-18 mich radial on the rear 18x4.25 allowing a 160-60 mich radial, both are sport touring tires that handle well and last a fair amount. depends on your $$$, my sporty needed wider trees, i was looking at pirelli diablo II's radials when the time comes, winter is near so riding will be little, unfortunately
rodhotter is offline   Reply With Quote
Old 11-01-2012, 04:46 AM   #10 (permalink)
Originally Posted by rodhotter View Post
the 140-70 is very close to stock diameter and works on our stock 17" rear rim, be aware of incorrect rim to tire sizing distorts the tread. having bigger rims will open up your choices...
Thank you. I'll be keeping the stock rims so the 140-70 will be it for the rear. Referring back to the OP, I think I'm getting from these replies that even though I'm increasing the width of the front and rear by 10mm over stock, I'm still limited to bias ply... correct?
Hilo
Larger Rear Tire mrcarb Twins Technical Talk 50 05-28-2012 01:12 PM
Stock front tire fot the 2007 T100? nagibe Twins Technical Talk 5 07-31-2010 12:39 AM
need tire advice (stock rims) dirtydutch Club Cafe' 31 05-21-2008 06:17 PM
larger front tire ??? Motoboard Twins Talk 8 10-08-2007 10:51 PM
tire recommendations of the sport-touring variety? redsled Speed Triple Forum 14 01-25-2005 07:03 PM
