Larger Sport Tire Recommendations for Stock T100 Rims? - Page 3 - Triumph Forum: Triumph Rat Motorcycle Forums
Old 11-10-2012, 12:37 AM   #21 (permalink)
Main Motorcycle: 2011Bonneville T100
Originally Posted by beemerrich View Post
+1. The best handling and grip came from the sport demons. In my case, I can get pretty much an entire riding season out of a rear and change out the front with every other rear...
Seems then that the SDs will be the way to go as "tire longevity" is my lowest priority. Thanks again,
Hilo
hilobemagical is offline   Reply With Quote
Old 12-12-2012, 10:38 AM   #22 (permalink)
Main Motorcycle: 2006 Scrambler
Other Motorcycle: 2001 Tiger
Extra Motorcycle: 1969 Norton 750S
[QUOTE=hilobemagical;2410684]My 2011 T100 is currently stock and I'd like to get some better tires that I can grow into. I've read enough of the tire threads here to know that what's offered in stock sizing is limited but that I can go up on size and have a much better selection of more sport-oriented tires. Beyond that I get confused at some of the mix-and-match solutions I've read about and would think there should be a matched set of great sport tires that can be accommodated by the stock rims.
Stock setup specs on the current tires:
Front- 100 / 90-19 M/C 57H; Rear- 130 / 80 R 17 M/C 65H
Front Wheel- 36-spoke, 19 x 2.5in.; Rear Wheel- 40-spoke, 17 x 3.5in.
I'm running 110/80 19 150/70 17 TKC 80s on my Scrambler. Prior to this I had Metzler Tourance 110/80 19 140/80 17 Both wore very well with the Tourance lasting 12K and still had life. I've read that you shouldn't oversize tires to your rims as this deforms the contact patch but I've had no issues.
snorton69 is offline   Reply With Quote
Larger Rear Tire mrcarb Twins Technical Talk 50 05-28-2012 01:12 PM
Stock front tire fot the 2007 T100? nagibe Twins Technical Talk 5 07-31-2010 12:39 AM
need tire advice (stock rims) dirtydutch Club Cafe' 31 05-21-2008 06:17 PM
larger front tire ??? Motoboard Twins Talk 8 10-08-2007 10:51 PM
tire recommendations of the sport-touring variety? redsled Speed Triple Forum 14 01-25-2005 07:03 PM
