11-05-2012, 05:02 PM
#11 (permalink)
SuperStock Main Motorcycle: Thruxton
Posts: 273 Other Motorcycle: Rieju Tango
Well you've got me stumped with the sock trick - don't really understand what you're trying to get at though.
The engine's running fine now, not hunting or rough running off-idle - warmed her up completely with no change - without the shims it got much worse as the engine heated up.
07 Thruxton: TEC 2 into 1, K&N, TTP Breathe Bellmouth, 135 mains, 40 pilots, std. needles, 1 shim (0.65mm). All baffles removed. Bitubo Fork Cartridges. Bitubo Rear Shocks. TEC Steering Damper. 3 Pot Nissin (Honda) brake caliper.
11-05-2012, 05:46 PM
#12 (permalink)
SOTP Vintage Series Main Motorcycle: 2005 Bonneville Blue 790
Posts: 7,144 Other Motorcycle: 1973 CB450, long gone
I had the same thing when I decided I couldn't leave well enough alone and took the single thin shim off each needle. What a difference a shim makes. I was surprised, I didn't expect it to change much.
Marty
11-06-2012, 12:23 PM
#13 (permalink)
Formula Extreme Main Motorcycle: '01 Triumph Bonneville
He's trying to make you run a bit richer with the sock .
11-07-2012, 05:26 AM
#14 (permalink)
Originally Posted by LukiSevenAce
It's possible there's more than 387% better "CFM" being delivered by the mod.
Try stuffing a sock in the throats, but use wool ones and not the synthetic type.
The wool sock will have a thread count on the package.
Look for a number between 250 & 350, but not higher than that; any higher thread count will cause the carbs to choke down more than you want.
You can turn the balled up sock (called 'indexing') 90° to adjust the idle too.
Turning it 45° will alter the tone of the exhaust note. (Look for a high C)
Good luck with it.
*I like the part where you know it's running 'just fine' without taking it out on the road.
Genius!
11-07-2012, 08:55 AM
#15 (permalink)
Supersport 400 Main Motorcycle: The One I Gots
Posts: 87 Other Motorcycle: Only This One Now
As far as a good AP goes, try "GForce".
I think there's a free version and a 'pro' version ($$).
The AP is only as good as the device it is 'reading', of course.
Reliance on the on-board accelerometer (a thing that isn't as big as the fingernail on your pinkie), is subject to scrutiny.
Like GPS devices have error, so will the smart phone you're using.
Though, and I'll give you this, it's great that y'all are willing to actually test performance of the mods in actual, road going situations.
I applaud that (and shall refrain from my petulant peanut gallery contributions to these threads.)
GForce Pro charts too.
Just looked up another one - Dynolicious. Seems to be more robust (than GForce being a mere display of the accelerometer in your smart phone.
Another one - Dynomaster (Android only it appears.)
"Feel" is either a noun or adjective. Lots of uses and meanings.
Applying it to a sensory experience, like 'feeling the bike pull', is strictly subjective analysis - and, thereby, fraught with error.
Putting a meter on the bike for testing and charting, is a great suggestion.
*Just a point about GPS -vs- accelerometer; they both have 'built in' errors. Like the average GPS is only accurate up to three meters, and is subject to noise, bias and deficiency.
Accelerometers (generally) measure only 'proper acceleration' and not rate of change velocity. The miniscule device in our phones, as mentioned, can be prone to error.
However, using any AP to rate or chart MC performance before and after a mod is better than the subjective analysis.
Anxious to hear/see the results. (sock or not.)
Reason: notation on GPS -vs- accelerometers
11-07-2012, 06:50 PM
#16 (permalink)
On that note I think I'll definitely "put a sock in it" (I may even try rotating it 90º just to make sure the noise reduction is adequate!)
11-07-2012, 07:27 PM
#17 (permalink)
Powerbike Main Motorcycle: 08 Street Triple
Posts: 384 Other Motorcycle: 2007 Speedmaster
Good luck with it.
Way to sock it to em!
