scrambler fcr39 jetting with zard low cross - Triumph Forum: Triumph Rat Motorcycle Forums
Old 10-21-2012, 05:08 PM   #1 (permalink)
Main Motorcycle: Scrambler
Hi there, I know there are lots of threads on fcr39 jetting but not having any luck finding what I'm looking for. Just curious if anyone has a similar scrambler set up as me and wonder what your jetting/needles are set to
Fcr39 / airbox removed (using unifilters) / Zard low cross / stock cams originally it was set up for TORs but with the zard it seems to be lean. For the needle I'm on the 3rd groove from the bottom (2 grooves showing) - still lean even at 160 mains...
Thanks in advance !
This pipe is awesome btw will post video soon
2008 Scrambler, BC-ARK, FCR39, Zard, TPUSA 813 cams, Works/Progressive suspension, other stuff, DIY at http://www.motomethod.com
WhoIsHayley is offline   Reply With Quote
Old 10-24-2012, 01:43 AM   #2 (permalink)
Ventura was kind enough to point me to this awesome link. Problem solved
Thanks Ventura!
http://www.triumphrat.net/twins-tech...ings-here.html
Man I love this pipe
Old 10-24-2012, 03:44 PM   #3 (permalink)
Main Motorcycle: Can't decide now!!
Ventura's Avatar
Other Motorcycle: Scram + Thrux
Extra Motorcycle: '71 BSA Thunderbolt
Problem solved
Thanks Ventura!
Glad to hear you're getting the jetting sorted Whoishayley!
And your bike is lookin' great with the pipes!!
Here's my Scram in its days with the Cross 'silencer'!?........
V.
2006 Scrambler, VARK'd, 155/40, 790 In-cam, Pieman'd igniter, DNA Pods, Zard 2:1.
2005 Thruxton, Black now, with ARK, FCR 39's & Uni's, Retimed 790 cams, Barnett clutch and suchlike!!
Ventura is online now   Reply With Quote
Old 10-24-2012, 06:41 PM   #4 (permalink)
B02S4's Avatar
Nice Scrams, gents.
Tried the referenced link twice & both times it pointed to the main page & not a specific thread...
B02S4 is offline   Reply With Quote
Old 10-24-2012, 11:14 PM   #5 (permalink)
Ventura's Avatar
This is the correct link to FCR settings...........
V.
Old 10-25-2012, 05:25 PM   #6 (permalink)
V.
This is the pic that helped me make the decision to go low
btw did you ever have the bird chirp with the low cross?
I don't mind it but just curious if you had it too?
Old 10-25-2012, 06:31 PM   #7 (permalink)
Ventura's Avatar
I dont recall any bird-chirping, or any other kind of whistling, with the pipes.
The fit between header and silencer was spot-on so unlikely from there.
I do remember tho, with the Cross fitted, an occasion where I started the bike up and it gave the biggest backfire imaginable, sending birds flying out the trees and the locals diving for cover!!
V.
Old 10-25-2012, 06:39 PM   #8 (permalink)
B02S4's Avatar
Thanks V.
Old 10-27-2012, 09:04 AM   #9 (permalink)
Newbie
Hello WhoIsHayley
i have the same exhaust and air filter on my scrambler and wonder what jetts you ended up with, I couldn't fined any post from you and your setting on the site you recommended.
So i would be glad if you could tell me.
ratbone is offline   Reply With Quote
Old 10-27-2012, 09:28 AM   #10 (permalink)
Main Motorcycle: 1965 TR6SR
rmak's Avatar
Other Motorcycle: 2007 Scrambler
Mine has that twittering sound. I read here that you can eliminate it by taking out the center post at the back. I don't find the sound that upsetting so I haven't modified the can..
rmak is offline   Reply With Quote
Zard Cross exhaust numbers VodkaAndPickles Twins Talk 37 10-18-2012 07:12 PM
zard cross - UK legal shutty Twins Talk 10 08-18-2012 04:46 AM
ZARD Cross... who has it, I need help installing shekmark Twins Technical Talk 2 11-25-2009 06:50 PM
need help installing Zard Cross 2-1 shekmark Twins Technical Talk 8 11-23-2009 08:47 AM
