2012 Bonneville Tank Removal Video - Page 3 - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear Motorcycle.com
Old 10-24-2012, 07:23 AM   #21 (permalink)
Main Motorcycle: 2012 Bonneville Mag Wheel
Pauljp's Avatar
Originally Posted by Mr*Beaver View Post
AI? Air Intake?
Air Injection.
It is the silver pipes that sit right beside the spark plugs.
You can see them in my video.
The purpose is to burn off impurities for emissions control.
There are kits to remove them and plug the holes.
The result is cooler running engines, less popping on deceleration, and easier access to the spark plugs.
Pauljp is online now   Reply With Quote
Old 10-24-2012, 06:59 PM   #22 (permalink)
Main Motorcycle: Bonneville SE
Great video! Thanks for putting it together. I'm not so nervous now about taking my tank off to wire the GPS and install the auxiliary power port.
Famer is online now   Reply With Quote
Old 10-26-2012, 07:42 PM   #23 (permalink)
Very detailed and thorough. Thanks!
smooth1 is offline   Reply With Quote
Old 11-04-2012, 10:12 AM   #24 (permalink)
Main Motorcycle: 2010 Triumph Bonneville
fullspeed's Avatar
Thanks so much! I'm replacing the washers to my weeping cam cover and was nervous about tank removal in my 2010. No more. Thanks!!!!
________________________
‎"Observe the masses... then do the opposite."
fullspeed is offline   Reply With Quote
Old 11-15-2012, 11:08 PM   #25 (permalink)
Main Motorcycle: 2010 Bonneville T100
Dynamo '73's Avatar
Nicely done ... just wanted to add my thanks, for this and the siphoning video as well. I am planning some wiring and AI removal, and this is invaluable.
Dynamo '73 is offline   Reply With Quote
Old 11-15-2012, 11:18 PM   #26 (permalink)
Main Motorcycle: 2013 triumph bonneville
very well done, and very thorough videos. it seems as if triumph did not over complicate the fuel tank/pump etc.
villageidiot327 is offline   Reply With Quote
Old 03-12-2013, 02:17 AM   #27 (permalink)
Main Motorcycle: Triumph America
BobKreyole's Avatar
Thanks for the videos.
You can get a good gas siphon from Home Depot for $2.98
http://www.homedepot.com/p/t/1003722...8#.UT7MBIXN4Tk
BobKreyole is online now   Reply With Quote
Old 03-12-2013, 11:28 AM   #28 (permalink)
Main Motorcycle: Buell XB12Scg
misternikko's Avatar
Other Motorcycle: Triumph Thruxton
what everyone else said. great job. this is the first bike ive owned that has that safety clip and i wasnt sure if it needed to come off or not. thanks so much.
misternikko is online now   Reply With Quote
Old 03-12-2013, 12:14 PM   #29 (permalink)
BobKreyole's Avatar
Moderator, can this posting be made a sticky? Great resourse material.
Old 05-08-2013, 11:56 AM   #30 (permalink)
Main Motorcycle: 2012 Thruxton
If all I am doing is removing the AI from the bike, is there any real need to remove gas from tank first?
Rick in MD is online now   Reply With Quote
baffle removal help for 2012 T100 jimmywalsh Twins Talk 3 09-21-2012 02:53 PM
1st Ride Video 2012 Triumph Tiger :) Carp Tiger Chat 1 04-01-2012 09:56 PM
Alpinestars 2012 Spring Collection Overview Video from STG Sportbiketrackgear.com Sportbike Track Gear 0 01-20-2012 04:11 PM
2012 Thrux Badge Removal JayLo Twins Technical Talk 0 11-05-2011 11:07 PM
2012 Yamaha Super Tenere Video wheat state Biker Hang-Out 1 10-30-2011 10:29 PM
