I replaced the pick up coil, but that didn't remedy the problem.
Luckily my mechanic was working on another Bonnie at the time and was able to systematically swap parts until he found which was failing. It turned out to be the ignitor.
Based on recommendations here on the forum, I went with the procom. It is getting installed today and hopefully I'll be able to go on a ride on Thanksgiving!
Just a suggestion:
Check the petrol filter, this could have become clogged. I've had recurring similar symptoms for a while. I remove the petrol tap and usually find sediment round the base.
Just a suggestion:
