Speedo has no power - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 22 (permalink) Old 10-10-2012, 08:25 PM Thread Starter
Main Motorcycle: T100
Speedo has no power
Hey guys in an attempt to get my speedo working i was just wondering if anyone knew what would be places to check that would power the speedo off a EFI speedo canbus. Is there a fuse somewhere other than the fuse box or wiring that could effect the speedo to no have power. My speedo is not even powering up , i don't see the clock displaying anything what so ever.
cheers
Rick
Bruno317 is offline
post #2 of 22 (permalink) Old 10-10-2012, 09:33 PM
DEcosse's Avatar
More info please - does everything else power up? Starts? Just no speedo? Idiot lights? (Oil Pressure, Neutral)
DEcosse is online now
post #3 of 22 (permalink) Old 10-10-2012, 11:14 PM Thread Starter
Tachometer powers up, the speedo has no power. The LCD display shows nothing and I'm not able to start the bike. This is a 2011 bonneville. What other places I can look too see if the speedo is getting power?
Bruno317 is offline
post #4 of 22 (permalink) Old 10-11-2012, 06:41 AM
Forchetto's Avatar
Here's a circuit diagram of the electronic speedo models if it'll help someone to trace your fault:
http://www.telecable.es/personales/v...eedo_small.jpg
The power for the instruments could be that red wire coming from the ECU pin B28, not sure though.
This is the layout of the ECU terminals and connectors:
Forchetto is online now
post #5 of 22 (permalink) Old 10-11-2012, 07:19 AM
Main Motorcycle: Tiger Explorer 1200 XC
welshrob's Avatar
Other Motorcycle: Moto Guzzi V7 Classic
I`m no expert but not being able to start the bike seems slightly more serious than the Speedo not having power?
At the risk of sounding like a master of the bleeding obvious, have you checked the kill switch?
On the digital speedo bonnies it cuts power to the speedo and the idiot lights, as well as the engine.
She said, "You can`t take ANYTHING seriously, can you?" I just laughed.
welshrob is offline
post #6 of 22 (permalink) Old 10-11-2012, 04:11 PM
DEcosse's Avatar
Originally Posted by Forchetto View Post
... The power for the instruments could be that red wire coming from the ECU pin B28, not sure though....
It's not actually Forchetto - the Red & Blue wires are the CANBUS data transmission.
Since there is no power to gauges NOR will it start, sounds more like the ignition power itself is not on - regardless of the gauges themselves being active, if the ignition circuit is complete, the neutral and oil pressure lights should at least be on.
The ignition circuit is the Green/Red on 3 & 4 of both instruments - however the problem is more likely to be further back
1) key-switch
2) Fuse #6 (check this first!)
3) Kill Switch
4) Alarm Bypass Connector Plug
Do the parking lights &/or the headlight &/or brake light/turn signals/brake light work? (please advise)
post #7 of 22 (permalink) Old 10-11-2012, 06:52 PM Thread Starter
Thanks so much guys for responding! Ok here goes.
-The lights come on, headlamp is working, signals are working, and rear tail lamp is working.
-Checked kill switch already and its ok.
-Looked in the fuse box and checked every fuse over twice so im pretty sure fuse #6 is ok
-On the tach side oil light is on, neutral light works as i tried to put it in gear and then back to neutral. Needle goes from left to right when i turn the power on via the ignition.
Now what is the Alarm bypass mechanism? Also im not sure if this can be a factor too is that the plug might have come into contact with moisture as it was outside when it was raining and i did see some water in both plugs for tach and speedo when i replaced gauges. I blew out the moisture with a air compressor before i plugged in gauges a day later so it would dry completely
Bruno317 is offline
post #8 of 22 (permalink) Old 10-11-2012, 07:11 PM
DEcosse's Avatar
Then you have ignition circuit working
Explain further re "replaced gauges" - do you mean you just unplugged and reconnected them while troubleshooting, or that you installed new, replacement gauges?
How/when did this problem first occur?
post #9 of 22 (permalink) Old 10-11-2012, 07:23 PM Thread Starter
Someone had hit/vandalized my bike when it was parked outside. Speedos were messed up so i replaced them. While i was waiting for replacements i had taken the speedo brackets and had it repainted so i uninstalled the gauges and left the wires unplugged which due to unexpected rain one day the plugs got wet. But i had blown them out dry and let sit for a couple days before installing new gauges.
Bruno317 is offline
post #10 of 22 (permalink) Old 10-11-2012, 08:20 PM
DEcosse's Avatar
Did you replace with new or used?
Did you try originals back in to see if does the same?
Instrument panel/speedo losing power sardinecan Daytona Deliberations 14 09-28-2012 03:35 PM
Speedo repairs Hinckley Speedo bon Twins Talk 0 01-11-2009 04:41 PM
MICHELIN TIRE RECALL power 2ct and power unummyu Sprint Forum 2 06-19-2007 01:53 AM
Figuring out the Speedo ratio-using alternate speedo clamp007 Twins Technical Talk 0 05-04-2007 02:15 AM
