An education on Bonnie lighting... - Triumph Forum: Triumph Rat Motorcycle Forums
Old 10-03-2012, 03:55 PM   #1 (permalink)
Main Motorcycle: 2010 T100 Black / White
... for me!
I hear a lot about the Hella and Cibie lights like this one
what I am trying to understand is why something with a clear lens like this one
or this one
wouldn't provide a brighter throw of light. It seems that in the Hella light, some of the glass is designed NOT to allow a lot of light through. I would imagine that's to prevent blinding oncoming traffic.
However, I would think that as long as you aim the light a little down and to the right (in the US) so as to not blind oncoming traffic, then the ones with a clear lens should give you more light?
Can someone please explain this to me?
Thanks
fernandos1 is offline   Reply With Quote
Old 10-03-2012, 04:00 PM   #2 (permalink)
Legend
Forchetto's Avatar
Older headlamp designs had a smooth parabolic reflector and relied on the lens ribs to shape the light beam. Newer types do the shaping at source, as it were, by having a multifaceted reflector to shape the beam and therefore a clear lens.
All modern vehicles have that now so I must assume it's more efficient or at least easier to manufacture.
Old 10-03-2012, 04:11 PM   #3 (permalink)
Ah Forchetto! I know would come through!!
The master again giving a lesson.
So the ones that I posted should work well, then. I really like the projector beam one and think that it would work well with the HID Kits.
Thoughts?
Old 10-03-2012, 05:29 PM   #4 (permalink)
Main Motorcycle: Black T100
fliplid's Avatar
The clear lense unit that came fitted from the factory on my '10 model didn't seem to put the beam anywhere useful. That's why I swapped to a Hella unit instead. I did make several attempts at realligning the original before swapping, and a couple of different bulbs as well.
Sent from my GT-S5670 using Motorcycle.com App
From the outside of the asylum.
fliplid is online now   Reply With Quote
Old 10-03-2012, 05:54 PM   #5 (permalink)
That's what I'm finding. If I adjust the low beam so that the top of the beam is high enough to be useful, the Hi beam lights up the sky. If I adjust the high beam to be useful then the low beam is 20 feet in front of me.
Sent from my iPhone using Motorcycle
Old 10-03-2012, 05:55 PM   #6 (permalink)
I think I'm going try the projector lamp setup with the HID lights.
Old 10-03-2012, 07:09 PM   #7 (permalink)
Main Motorcycle: Bonneville se
captainwoot's Avatar
lighting
I just installed a hid bi xenon 6000k, in my 12 mag wheel bonnie and i love it. I have used hid's in my last three bikes and will never go back.
"Evil Triumphs When Good Men Do Nothing"
captainwoot is offline   Reply With Quote
Old 10-03-2012, 07:54 PM   #8 (permalink)
did you use the original lamp? where did you get the HIDs?
Old 10-04-2012, 10:10 AM   #9 (permalink)
Main Motorcycle: 02 Bonneville
ivar's Avatar
Other Motorcycle: 93 Dnepr MT-16
Extra Motorcycle: 05 SV650S
I'd say the Hella I got is a lot clearer than my stock reflector/light to the left:
02 Bonneville - 904 wiseco/813 cams/FCR carbs/Dominator touring, ARK,AI,.Pieman igniter. Thruxton seat, superbars raised 1". Intiminators/Öhlins PL36 shocks, renntec rack.. Tourance tires , D9 bracketry
ivar is offline   Reply With Quote
Old 10-04-2012, 10:38 AM   #10 (permalink)
357Bob's Avatar
I have been been thinking about HID's too. But I still
like my Marcel housing with the 80-100 watt bulb.
Marcel's are expensive. Hard to find. I wired 2 relays
to the bulb for a full 12 volt at the connector. More light
than my car. I didn't like the Hella. I doubt it matters
if the facets are in the lens or the reflector if done right.
357Bob
Looking for an Education TrumpetRat Twins Technical Talk 6 07-17-2011 11:02 PM
Higher education Naticus Biker Hang-Out 131 04-20-2011 06:01 AM
Riding Education for Kids? brolane Biker Hang-Out 14 09-27-2007 06:51 AM
Sprocket Education HooliganRandy Triumph SuperSports 7 10-18-2006 11:51 PM
New Triumph owner - parts and self education slash5bmw Classic, Vintage & Veteran 5 09-13-2004 09:41 PM
