Subframe LED indicator mod - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
Old 08-31-2012, 05:13 PM   #11 (permalink)
Main Motorcycle: 2012 Bonneville base
Just ordered those. Now to figure out if I want to DIY a tail light or get the mini fender.
Thanks for the info.
gurbik is offline   Reply With Quote
Old 08-31-2012, 05:18 PM   #12 (permalink)
Junipero's Avatar
Other Motorcycle: 2011 BMW R1200RT
Nice work, fancypants. Now remove that passenger peg and slim her down even more!
"The views expressed here are my own and do not represent my employer's position or opinion."
Junipero is online now   Reply With Quote
Old 12-03-2012, 03:15 PM   #13 (permalink)
Other Motorcycle: 2004 Thrux
Extra Motorcycle: XR440R
Looks great!
untoldmiles is offline   Reply With Quote
Old 12-03-2012, 05:23 PM   #14 (permalink)
Main Motorcycle: '07 Bonneville T100
zenbike's Avatar
Other Motorcycle: '01 Sprint RS
Looks very nice. Is that just the stock seat with the pan and foam trimmed and the cover stretched back on?
Thinking this is the route I'll try next. If I like it then I will invest in a new cover fit to the trimmed seat.
zenbike is online now   Reply With Quote
Old 04-04-2013, 07:53 PM   #15 (permalink)
Main Motorcycle: 2011 Triumph Scrambler
Other Motorcycle: KTM 400 EXC
Extra Motorcycle: 81 XL500s
Where did you drill the holes.
If possible could you post a pic of where you drilled the holes; I am about to do this myself but am a little concerned where to drill the holes so I don't compromise the structural integrity of the bike.
Cheers
Matt
mattyh76 is offline   Reply With Quote
Old 04-05-2013, 09:22 AM   #16 (permalink)
francypants's Avatar
Cheers
Matt
Don't have a picture at the moment, but it probably makes the most sense to drill somewhere near the battery or igniter unit, especially since the subframe is fortified there. The holes needed are pretty small. I ended up drilling near the rear because this was a temporary mod to me, and I was going chop/shorten the rear subframe anyways.
Make sure the edges of the newly drilled holes aren't too sharp as you don't want them cutting into the wires and leading to a short.
francypants is offline   Reply With Quote
Old 04-05-2013, 02:16 PM   #17 (permalink)
Main Motorcycle: 2009 Bonnie EFI
TX1911fan's Avatar
I'm thinking of doing this in addition to my current LED rear tail lights to just give more light back there.
TX1911fan is offline   Reply With Quote
Cracked subframe fix ralphus Sprint Forum 30 05-22-2013 02:43 AM
Red subframe on red '11+ S3? GotBoost2JZ Speed Triple Forum 10 03-06-2012 10:35 PM
Rear Subframe gettin2dizzy Speed Triple Forum 0 09-29-2009 10:27 AM
Need a new subframe... FrankD Hinckley Classic Triples 10 10-11-2008 07:21 PM
S3 subframe compatibility zeus_r6 Speed Triple Forum 5 04-13-2007 09:58 PM
