08-23-2012, 09:16 PM
Headers Glowing Red Hot
Just got in from a ride. Let the bike idle for about a minute in the driveway, and I noticed that the headers, right at the first bend where they attached to the motor, were glowing red hot. I shut the motor off, and within 3 seconds the red was gone. Is this normal?!?
08-23-2012, 10:23 PM
Powerbike Main Motorcycle: 06 Thruxton
Posts: 391 Other Motorcycle: '69 Bonneville Extra Motorcycle: '71 Bonneville
I've never noticed them after a ride but if I let the bike sit at a high idle, say 1500-2000 RPM they will glow red. Even if I position a box fan or two on either side of the front wheel it still does it eventually glowing about half way between the first and second bend. I usually quit by then and wait for it to cool down before continuing.
Seems scary but I don't notice any adverse effects.
Art.
08-24-2012, 12:07 AM
Site Supporter Formula Extreme Main Motorcycle: 2006 Thruxton CaspianBlue
Posts: 481 Other Motorcycle: HDtouring Hondaoffroad MX Extra Motorcycle: YES...
meltdown normal
normal
but don't let it idle too long but
it is normal, on single wall headers
see it on the race bikes a lot
it does seem strange to see
when you first see it
08-24-2012, 07:43 AM
Thanks for the replies. Glad to hear that it's not unusual. Was afraid that something was seriously wrong.
08-24-2012, 03:09 PM
SuperStock Main Motorcycle: '12 Thruxton
I had a Honda 450 dirt bike with a Yoshi pipe on it that would glow white it got so hot. My buddies would light their cigarettes off it.
08-24-2012, 03:15 PM
SuperStock Main Motorcycle: 2001 Bonnie
Posts: 296 Other Motorcycle: 2002 Bonnie Extra Motorcycle: 1250 K8 Suzuki Bandit
You don't say what model or year you have, but this was a common complaint right from the start. My 01 would glow almost to the mufflers. Solution, ditch the AI and use some freer flowing exhausts.
08-25-2012, 05:02 PM
It's a 2008 Thruxton. AI removed, with TORs.
08-26-2012, 05:21 AM
Formula Extreme Main Motorcycle: Bonneville T100 EFI
Well with the AI removed and TORS that doesn't sound normal at all. You're either thrapeing the nuts off the bike or there is something causing it to seriously over-heat. I would be checking the fuelling as it sounds like you are running very lean to me.
Bonny - '10 Bonneville T100 with saucy Dominator pipes, de-snorkel'd, de-AI'd, UNI air filter; De-OČ sensors.
2004 Jaguar S-type V8 4.2
08-26-2012, 05:39 AM
Site Supporter Team Owner Main Motorcycle: 2003 Bonnie
Posts: 4,762 Other Motorcycle: 2003 Speed Triple 955i Extra Motorcycle: Monkeybike!
A haiku:
Your headers glow red
Fear not, this is quite normal
But don't touch it, yeah?
If knowledge can create problems, it is not through ignorance that we can solve them.
Isaac Asimov
08-26-2012, 09:21 AM
Powerbike Main Motorcycle: '10 Thruxton
Rejetted for the TORS?
