Headlight - Triumph Forum: Triumph Rat Motorcycle Forums
Old 07-31-2012, 12:17 PM   #1 (permalink)
Headlight
I know the headlight on the Bonneville T100 isn't the greatest in the world. But I think mine is slightly worse than normal. I put the long haul screen on and I think that I have not aligned the headlight properly.
I seem to remember that you could properly line up a headlamp beam by making a mark a certain distance up a wall then have the bike on level ground so it was facing the wall from a certain distance and then adjust the light till the top of the beam just touched the line on the wall. In this day and age there is probably another method.
Anyone have any advice on this
Thanks
MrGromit is offline   Reply With Quote
Old 07-31-2012, 01:51 PM   #2 (permalink)
Legend
Forchetto's Avatar
With the bike on its wheels and you astride, have a helper measure the distance from the floor to the center of the headlight lens.
Pick a flat wall where you can locate the bike so the headlight is 17 feet from the wall. Place a horizontal mark on the wall two inches lower than the height of the center of the headlight.
The headlight beam (on low beam) should be relatively flat on the top, and may rise rather sharply at the right edge. Adjust the headlight vertically so that the flat top of the beam is just up to that line (marked two inches down at 17 feet).
Horizontal adjustment should center the beam ahead of the line of the bike.
Page 97 of the owners handbook has instructions as well, but the above is very simple.
Old 08-01-2012, 08:44 AM   #3 (permalink)
Thanks. I remember doing something similar on my Suzuki GS1000 many moons ago
Old 11-23-2012, 01:07 PM   #4 (permalink)
Main Motorcycle: BMW R1200RT
Other Motorcycle: 2002 T100 Centennial
I thought it was 25 feet back?
gregpinch is offline   Reply With Quote
Old 11-23-2012, 11:26 PM   #5 (permalink)
gjones's Avatar
heh, heh I use the 25ft rule also. But its a generic rule. Perhaps this is a Bonneville thing. I'll check it at 17ft in the Spring, and see if there is much difference.
Sonofabitch. 4 months to ride. Fk.
gjones is offline   Reply With Quote
bike dies / no headlight / shorting of fuse / headlight wiring sangalfie Classic, Vintage & Veteran 14 10-22-2009 12:23 PM
Under headlight bag (?) Ken M1 Street Triple Forum 0 04-04-2008 11:44 PM
