Wanted: Acewell Gauge experiences - Triumph Forum: Triumph Rat Motorcycle Forums
Old 07-26-2012, 03:58 PM   #1 (permalink)
Main Motorcycle: 2004 Thruxton
Other Motorcycle: 1954 BMW R25/3
Extra Motorcycle: 1971 CB350
Hi All,
I'm going to be shifting to an electronic speedo in the near future and am warming up to the Acewell 2856 unit for my carbed thruxton:
http://www.acewell.co.uk/Acewell%20S...ion=full&id=18
Searching the archives, I've not found much of anything in terms of commentaries on the reliability/mounting options/or general satisfaction with these gauges...only vague references, incompatibility issues with EFI bikes, and this post:
http://www.triumphrat.net/twins-talk...ml#post1418627
I am indebted to anyone who can share their experience with this manufacturer.
Thanks,
--Rich
beemerrich is offline   Reply With Quote
Old 07-26-2012, 04:05 PM   #2 (permalink)
Main Motorcycle: 2006 Speedmaster
I have the Acewell 2856 and I find at the blue back light at night makes it hard to read the speedometer. Others have said that is not a problem for them. Other than that I like it...would like to find something to wire out fuel gauge...the fuel bar flashes...
jimg010 is offline   Reply With Quote
Old 07-31-2012, 12:20 PM   #3 (permalink)
Thanks for the input Jim. Anyone else want to comment on ease of install, reliability, overall satisfaction, etc.?
Thanks,
--Rich
Old 07-31-2012, 08:38 PM   #4 (permalink)
Retro-Racer's Avatar
Rich,
You'll want to get a hold of Jeremy at LCFrabrications and order his speedometer elimination spacer so you don't have to run a stock speedo without the cable.
The Acewell's are as good as anything else out there. I agree about the blue dial lighting, but you're never one to watch his guages anyways.
/M
"With integrity, nothing else matters. Without integrity, nothing else matters."
Retro-Racer is offline   Reply With Quote
Old 08-01-2012, 08:57 AM   #5 (permalink)
Mike,
I've seen those LC Fab spacers and they're top shelf. However, I'm probably going to fit the pulse transmitter to the speedo drive...Acewell offers a triumph specific unit that eliminates the need to do the magnet/sensor install on the wheel/fork leg and grabs the signal off the rotating drive.
Cheers,
--Rich
Old 08-01-2012, 09:43 AM   #6 (permalink)
They do? Too cool!
/M
Old 08-01-2012, 06:51 PM   #7 (permalink)
They do? Too cool!
/M
Yeah, way cool...check it out:
http://www.acewell.co.uk/Acewell%20A...rive/index.htm
The ACE-S8 unit is the one for our bikes...
Cheers,
--Rich
Old 11-21-2012, 05:22 PM   #8 (permalink)
Main Motorcycle: 2009 Bonnie EFI
TX1911fan's Avatar
Cheers,
--Rich
Beemerrich, I just ordered the Acewell and that Triumph specific cable. How hard was it to wire up all the idiot lights in the speedo?
Also, how does the fuel gauge work? Does it just notify you when the tank is close to empty like the stock light?
TX1911fan is offline   Reply With Quote
Old 11-21-2012, 07:29 PM   #9 (permalink)
My minigauge setup was pretty easy to wire, but since I've yet to commit on electronic speedos I can't comment on the Acewell unit. The lack of shared experience on the Acewell lead me to explore other options before pulling the trigger.
Like the speedhut offerings. These are GPS modulated and don't require any sort of pulse transmitter (thanks for the lead, Seth):
http://www.speedhut.com/gauges/GPS-speedometers
And the various options on the digital-speedo site:
http://www.digital-speedos.co.uk/index.asp
I need to pick at some point this winter since I no longer have a speedo drive on the front wheel....though the lack of speedo & tach hasn't kept me off the street for the past few months.
My thruxton is an '04, so I can't help you with the fuel gauge either. Please post some feedback on the install & gauge after sorting it out since no one else seems to have fitted this gauge - or at least on one wishes to share their experience if they did.
Good luck with your project.
Cheers,
--Rich
Old 11-21-2012, 09:04 PM   #10 (permalink)
Kudos Rich!
By linking me to the Acewell site and the pulse speedo cable, I discovered that certain Honda's and BMW's use the same speedo cable attachment as the NTB.
This will be of particular interest to those wanting a pimped-out cable (SS braid covered) or just a cheap take-off replacement.
/M
Acewell Flatonr Twins Technical Talk 16 12-21-2012 05:04 AM
Acewell 2853 w/ EFI Bikes cashmore1985 Twins Technical Talk 11 08-01-2012 12:51 AM
Oil pressure gauge experiences wanted Forchetto Twins Technical Talk 14 12-18-2009 06:48 PM
Scrambler stories and experiences wanted... Casper Twins Talk 1 11-03-2008 12:54 PM
