Unable to start bike after a minor modification. - Triumph Forum: Triumph Rat Motorcycle Forums
Old 07-05-2012, 02:27 PM   #1 (permalink)
Main Motorcycle: 2005 Thruxton
Other Motorcycle: 2009 HD Ultra Classic
Long time reader; first time poster.....but here's my tail of woes...
After collecting several used parts from Ebay suppliers, I just modified the foot controls on my 2005 Thruxton from the set back stock location, to the mid control position of a Bonneville.
(I don't bend like I once did)
This involved installing Bonneville foot pegs and hangers, brake pedal, gear changer and brake master cylinder.
The only electrical interaction was the pressure switch that controls the brake lights.
The brake lights appear to work fine after the change.
However, post modification I have had difficulty starting the bike.
After several hours of tinkering with connectors I was able to get it running, although I don't know what I did that made it work.
I then took the bike for a local ride with a couple of stops.
The bike restarted easily when warm.
Tried again last night to start the bike after several days and I cannot start it again.
Tinkering didn't do it this time.
The starter relay clicks, engine turns over, gas is on, choke is pulled, but engine
doesn't appear to fire.
I don't understand how the foot control modifications could possibly affect the starting and suspect that it is just coincidental timing.
With that thought, I pulled each spark plug and was unable to see any sparking in a dark garage when I tried to start the bike again.
My thoughts were to replace the spark plugs, which are likely 7 years old and a
cheap investment.
That didn't do it, so the plan now is to work back through the ignition system.
Does anybody have any advice on trouble shooting this situation?
thanks
Brock42 is offline   Reply With Quote
Old 07-05-2012, 06:22 PM   #2 (permalink)
Main Motorcycle: '99 Legend / '98 TBS
BigAl8295's Avatar
Maybe your battery is shot.
FCR-39 Carbs, Sprint Cams, British Customs Predator Exhaust, K&N Pod Filters, Nology Coils, Ignitech Ignitor, Progressive Fork Springs, ZX-6R shock, and one bad ass Horn Cover!
Charm City Mods vs Rockers Rally
BigAl8295 is offline   Reply With Quote
Old 07-05-2012, 06:36 PM   #3 (permalink)
Legend
Main Motorcycle: '07 Bonneville
Haggis's Avatar
Other Motorcycle: Sprint RS
Moved for more input.
The battery could be 7 years old!
Haggis is offline   Reply With Quote
Old 07-05-2012, 09:52 PM   #4 (permalink)
Battery is fully charged and on a tender while I play with the bike.
It was new two years ago when I had a previous electrical issue, replaced the stator and regulator/rectifier then too and had no worries until now.
I've just changed plugs which did nothing (wishful thinking) and am heading back to the garage to start looking at other ignition components.
Old 07-06-2012, 09:22 AM   #5 (permalink)
Main Motorcycle: 2010t100 67 ttspecial rep
mike-tt special's Avatar
Other Motorcycle: 91 zxr750(805cc)
did you have the seat off the bike when you did the work, some have had problems with the seat pressing on the ecu connectors causing bad connection
mike-tt special is offline   Reply With Quote
Old 07-09-2012, 09:21 AM   #6 (permalink)
richm's Avatar
I would start looking for the problem around where you were working...... How about the kick stand cut-out switch - maybe with the changes you made, it got knocked out of position - or it's connector?
richm is offline   Reply With Quote
Old 07-09-2012, 09:32 AM   #7 (permalink)
the kickstand switch and neutral switch are both bypassed with the clutch pulled in, might try pulling in the clutch while stateing and see if that gets your spark back.
cliff
2006 Bonnie Black
1980 Yamaha xs650 sold 4-30-2011
alfacliff is offline   Reply With Quote
Old 07-09-2012, 10:58 AM   #8 (permalink)
Main Motorcycle: The One I Gots
LukiSevenAce's Avatar
Other Motorcycle: Only This One Now
<ditto this one>
Probably tugged on the connection and it's loose, not out.
"Intermittent", it is a German word.
Good luck and report back on results (if you please.)
LukiSevenAce is offline   Reply With Quote
Old 07-11-2012, 06:48 PM   #9 (permalink)
I think it's my HT Coil
It does not appear to be one of the cut out switches (clutch or kickstand).
Both the kickstand and the clutch switches seem to prevent the engine form turning over and my engine does turn over when I push the ignition switch.
I know this because I intentionally tried starting the bike in gear with the kick stand down just to see what would happen and absolutely nothing does.
Pull the clutch in and it turns over, just like it does when the bike is in neutral.
I've also disconnected and reconnected every connection along the wiring harness, including the ones in the light bucket.
I also pulled the tank and checked the HT coil.
Power appears to go in but nothing comes out, not thru the spark plug or thru a circuit tester when I push the ignition.
I tried this directly from the coil to block, thru the spark plug wire to the block, thru each spark plug to the block and even touching the spark plugs together while touching the block (that last one was tricky with just two hands).
I checked the primary and secondary resistance thru the coil using a multi tester, as per my maintenance manual.
Assuming I did that correctly (big assumption) I believe the coil is NFG.
Based on the $160 cost of a stock coil at the dealer and a $75 cost for a Nology coil from the good folks at BC, I ordered the latter.
It will take a couple weeks to come, but the stock one would have too, at twice the price.
I also ordered some Nology wires and plugs, all for less than the cost of the stock coil.
Timing works because I'm away anyway.
I'll report back back once I plug the new parts in.
Hopefully this does the trick.
Inshallah!
Old 07-12-2012, 11:37 AM   #10 (permalink)
don be too suprised if the new coil connections are thinner and smaller than the origionals. mine was. my starting trouble was ninally the ignition module, the seat had rubbed on it, and it was dead. a new procom unit and my Bonnie is running like never before, and getting better gas mileage too.
cliff
2006 Bonnie Black
Minor Crash = Totaled Bike?! Lomexx Sprint Forum 39 08-07-2011 02:54 PM
Unable to start in cold Chicago weather - FIXED! Hansonb4 Twins Technical Talk 8 02-24-2011 07:44 AM
unable to start timboellis Trophy 17 01-17-2011 11:26 AM
Bike won’t start after minor crash. Aurelius Speed Triple Forum 9 11-17-2007 11:05 PM
Unable to start 77 bonne tokarz33 Classic, Vintage & Veteran 15 12-08-2006 06:00 PM
