Stock mirrors - Triumph Forum: Triumph Rat Motorcycle Forums
post #1 of 6 (permalink) Old 06-09-2012, 09:45 AM Thread Starter
Fyr
Main Motorcycle: Bonnie (Withnail)
Fyr's Avatar
Other Motorcycle: 79 Honda
Stock mirrors
So Ive got the bike prepped for a nice weekend trip to the mountains. All serviced and ready to roll.. However the left mirror has always been loose. Then the young lad just touched it and it swung away..No prob.. Ill tighten...
Hahahaha
Of course the PO probably thought the same thing... Allen head stripped.. OK Just a wee bit of snugness is all I need.. Well... You know the rest..
Snapped bolt - Yes I used a vice grip. Just needed it to hold tight.
Pulled the stock, tapped out the rest of the errant thread and put in new Metric bolt and nut.. Looks horrible and works the same..
Time for new mirrors (go Stock or something slick) I am not really sold with bar ends as I dont really like adding things that can snag..
If I get a used stock mirror, does the small collet in the lever hole need renewing? Its a small tin like sleeve..
Anyway, Ive got 5 days to sort this or go old school.... And twist my head left a lot!
cheers
07 T100 Black and red..Farkling underway....
Bye-2008 Ural Gear Up 2wd-77 BMW R100S-04 KLR 650
01 Bonnie- K&N, bafflectomy, OEM gaiters, m-bars, UK tax-disc, seat bolts, Dart screen, ongoing! 34K+ (sold at 38K)
Many others, no space!
Fyr is offline
post #2 of 6 (permalink) Old 06-10-2012, 02:58 AM
Askari's Avatar
Not the first.
This has happened to a # of people, the looseness. It would seem that the solution was a washer, if i remember right i drilled it to fit over the collett, then when tight sucker didnt move.
So in answer to your question i think the collet is the culprit and a new collet might just be a new culprit. The washer works fine mine hasnt budged in 3+ years.
There are probably lots of 2nd hand ones about post an advert see what happens.
Askari is offline
post #3 of 6 (permalink) Old 06-10-2012, 06:02 AM
Main Motorcycle: Bonneville T100 EFI
Hahahaha
cheers
I read that you are not a great fan of bar-end mirrors but I have to tell you that the ones I've just installed are so much of an improvement that I could hardly believe it possible.
They are 3inch convex mirrors, so not too large but the rearward view from them is just incredible. I can so both sides of the road - in both mirrors !!!!!!!!
So no more nasty surprises of cars coming past without me knowing - sure I know that you can adjust your std mirrors to help with the blind spots, but only to a certain extent.
Now I find that I can see traffic coming up behind me from way back, and I can follow their progress very easily and clearly and it makes a big difference to me not just in actual security but also in the feeling of security as I can plan my ride better.
It should perhaps be noted that I have a - ahem - manly figure, so if you boy-shaped guys out there don't have any issues now, you might do in later life when the pleasures of wine and food have taken their toll
By the way, I bought my bar-end mirrors of Ebay, brand new and they cost, wait for it, ...............................£0.99 plus shipping. So I reckoned they were worth a try, and they certainly are.
Dave
KTM 1190 Adventure
thebiglad is offline
post #4 of 6 (permalink) Old 06-11-2012, 10:08 AM
Main Motorcycle: 2007 Triumph Bonneville
mightydaj's Avatar
Other Motorcycle: 1974 Norton 850 Commando
Extra Motorcycle: 1967 305 Honda scrambler
I did the same thing to my mirror. In all the messing around with the mirror stalk the collett got a bit "flattened" and was even looser than before. I wrapped it with tin foil for a while to make it tighter. It worked sort of but not to great and did not last long. Eventually I got a new collett and the mirror stays put just fine now.
mightydaj is online now
post #5 of 6 (permalink) Old 06-11-2012, 10:37 AM
Main Motorcycle: T100
lewilewi's Avatar
Other Motorcycle: Fazer
V star or V max mirrors with fit the bonne stock mirror fitting and they look much better then stock .
http://www.triumphrat.net/twins-talk...r-mirrors.html
cheers lewi
lewilewi is offline
post #6 of 6 (permalink) Old 12-04-2012, 03:55 AM
Main Motorcycle: Bonneville SE 2012
Good day
What are the guys that eplce their standard stock mirrors with the bar-end type doing with their Standard stock mirrors ??
I dropped my Bonneville 2012 se and broke the left standard mirror.
Anyone got a spare going?
I just need the top section as the stalk is perfect.
Cheers
OldManZulu is offline
Stock Mirrors usmcdude Twins Talk 1 07-27-2008 10:15 PM
Link for the homemade bar end mirrors from stock mirrors? cf04thruxton Club Cafe' 13 06-17-2008 10:04 AM
stock mirrors Texas Threesome Speed Triple Forum 13 11-06-2007 09:47 AM
stock mirrors 2bugeyez Speed Triple Forum 2 08-19-2004 09:20 PM
Want to Buy 97-02 Stock Mirrors!! joeygloor Speed Triple Forum 0 07-19-2004 08:17 PM
