bonneville runs at idle/riding just stuts down - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Motorcycle.com Classifieds!
Old 06-04-2012, 02:47 AM   #1 (permalink)
Main Motorcycle: bonneville 790
ok bought a 05 triumph bonneville crashed on the left side finally finished it, and riding for a week then when riding with a passenger 4 miles away from home it just shut off, i was down shifting and coming to a stop when happened. After that tried starting tell battery had nothing, it just cranked and cracked. So the next day I started the search, started at the battery bought a new one sence i killed the other one, it started right up. so i put it back together went for a ride three blocks later it shuts off but still has power and can turn over but no start, so pushed it back home. Went in side for a bit, came back outside and it started right up no problem. I let it run at idle ran for about 5min then stut down agian. has gas flowing out of the petcock, so i know its not gas or air. when it died i checked for spark nothing, then after letting it sit for awhile it start up like a champ shut it off so i could check for spark and it was there spark!!! im down to cdi box(igniter) or pick-up coil. any thoughts out there?
pacotaco is offline   Reply With Quote
Old 06-04-2012, 09:37 AM   #2 (permalink)
I had the same problem with a similar bike. I tracked it down to the pick-up coil. See the following post for details...
http://www.triumphrat.net/twins-tech...arming-up.html
also, once it quits you can measure the pick-up coil resistance to determine if it has failed.
applejack is offline   Reply With Quote
Old 06-15-2012, 06:40 AM   #3 (permalink)
waiting on part from over seas, its been 10 days already so hopfuly it will be soon. what tool did you use to get the .8mm?
Old 06-17-2012, 12:40 PM   #4 (permalink)
I used a feeler gauge from Autozone or some other automotive parts store. The one I bought, for about $6 is .0015-.025 inch [0.038-0.635mm]. I had to stack two blades 0.381mm and 0.406mm to get 0.8mm.
Old 06-18-2012, 07:00 PM   #5 (permalink)
Bought a feeler guage from sears. it had .032 on it which is o.8 for the gap need for the pick up coil. Pulled apart and back together with in the hour but had to wait 14 days from triumph. Needless to say it worked and runs like a champ. Thank you applejack
2007 S3, runs rough at idle, low end?? Crogers Speed Triple Forum 2 09-23-2011 02:29 PM
NO Idle runs fine....help rcarpent Hinckley Classic Triples 11 08-13-2009 12:27 PM
99 daytona 1200 runs rough @ idle and high rpm's JAY991200 Daytona Deliberations 4 07-02-2009 07:42 AM
runs fine untill shutdown/restart no idle and rough Sprint Forum 1 06-02-2005 07:05 PM
new bonneville ????? runs rough Maintenance & Workshop Talk 14 10-04-2003 04:08 AM
