According to the Triumph in-house
Training Support Notes: Engine Management & Electrics manual a Keihin EFI equipped bike can be adapted
without resetting the ECU/ECM. Here is the Triumph factory-approved method
verbatim from the manual:
1. Ensure coolant is at ambient temperature
2. Start engine and allow to warm without touching the throttle until the fan comes on
3. Leave the engine to idle for a further
12 minutes.
Important Note: This procedure assumes the bike has a Lambda 02 Oxygen Sensor connected and is therefore a
closed loop system
