Rear Brake Master Cylinder Relocation 09 Bonnie - Triumph Forum: Triumph Rat Motorcycle Forums
Old 05-22-2012, 06:27 PM   #1 (permalink)
Main Motorcycle: 09 Triumph Bonneville
Other Motorcycle: 08 Yamaha Tour Deluxe
Extra Motorcycle: 78 Suzuki GS750E
I'm relocating my rear master cylinder for clearance with the scrambler exhaust I'm installing. Two rotate the MC to the left and attach it to the rear frame rail.
The other option is to mount it lower like the Thruxton and Scrambler near the pedal. The problem is the pushrod is the long version.
My question is has anyone shortened their pushrod by cutting and rethreading?
Shopshirt is offline   Reply With Quote
Old 05-22-2012, 08:12 PM   #2 (permalink)
Askari's Avatar
M/C cylinder
I have been considering making some rearsets and have been looking at changes. You might want to have a look at the norman hyde reasets and the way they move the cylinder. Might give you some ideas.
Askari is offline   Reply With Quote
Old 05-22-2012, 08:40 PM   #3 (permalink)
6t
Main Motorcycle: The one that I am on
6t's Avatar
Other Motorcycle: 2002 Bonneville America
Extra Motorcycle: Honda RC30
I cut and re threaded mine when I installed Scrambler pipes. I also installed the rt peg hanger to mount the m/c so I had less to worry about.
2002 T100 Anniversary. Lucifer Orange no more, "Scrambled"
Brakes and suspension, various Scrambler parts, speedo/tach in headlamp .
6t is offline   Reply With Quote
Old 05-22-2012, 10:20 PM   #4 (permalink)
I looked at the Norman Hyde set up and it seems the scrambler pipes would still rub against the master cylinder.
6t do you have a gallery or some pics of your setup? I'd like to check it out.
Old 05-22-2012, 10:30 PM   #5 (permalink)
Old 05-22-2012, 10:42 PM   #6 (permalink)
Nevermind 6t found your old post:
http://www.triumphrat.net/twins-tech...bled-t100.html
I'm also assuming you had to install longer brake line and brake light swithch cable.
Old 05-23-2012, 10:10 AM   #7 (permalink)
6t
6t's Avatar
I had to lengthen the brake switch wires a little. I used the same brake hose, just had to route it a little differently. I think it is longer than the Scram item, not too sure, but it's been fine for the last few years.
If you use the Scrambler pipes/mufflers you will need to weld a bracket to the rt top subframe to take the weight of the mufflers.
Old 05-23-2012, 05:13 PM   #8 (permalink)
6t
6t's Avatar
In case you need it here's a pic of the rear muffler hanger that I welded to the top frame rail. I saw it in a hardware store. it was supposed to be a gate hinge but it looked the part and was stong enough, and not too expensive.
Need Quick Advice - rear brake master cylinder txpunk T3 Sport / Touring Forum 14 03-30-2012 01:33 PM
rear brake master cylinder t300 T3 Sport / Touring Forum 2 11-27-2011 01:00 PM
aftermarket Bonnie front brake master cylinder... killian101 Twins Talk 8 02-23-2011 03:31 PM
rear brake master cylinder parts needed motor_head666 Twins Technical Talk 0 11-05-2010 10:30 AM
2008 Scrambler front brake master cylinder relocation Rettig Twins Technical Talk 0 07-09-2008 09:30 PM
