04-26-2012, 07:01 AM
Site Supporter Supersport 600 Main Motorcycle: 2010 Triumph Bonneville
Joker Ignition Relocation help...
Quick question. Got the Joker machine ignition relocation bracket. Is there any wiring involved or do I just relocate the original wires. There's no mention of any wiring or soldering on the BC or the JM website.
________________________
"Observe the masses... then do the opposite."
04-26-2012, 07:17 AM
SuperBike Main Motorcycle: '07 Black
I had to do no wiring on mine; the switch isn't relocating that far away. The whole job took maybe 30 minutes.
"Cognito Ergo Wrenchum"
04-26-2012, 07:24 AM
Thanks Easy13!
06-07-2012, 03:35 PM
Supersport 600 Main Motorcycle: 2012 mag wheel Bonnie
The Joker component uses the stock frame screws, right? Do you know how hard those need to be torqued back down?
Thanks.
06-07-2012, 05:21 PM
Formula Extreme Main Motorcycle: 2009 Bonnie EFI
No, the Joker one comes with new screws. I just tightened them tight, didn't torque them. I probably should have.
06-07-2012, 11:07 PM
Formula Extreme Main Motorcycle: Bonneville
Posts: 514 Other Motorcycle: BMW GS 1200
I just installed a kit similar to the joker and the cable was not long enough out of the headlight. I had to pull out the connector to get more slack. I tucked in the connector behind the headlight, behind the ear.
Odd enough a friend of mine has a similar set up on his 06, but no issue with the wiring. My is an 07. I guess mine must have had a shorter wire.
I believe the screws will need to be torqued to 45 nm.
Sent from my iPhone using MO Free
2011 BMW GS 1200
2007 Bonneville Black
06-07-2012, 11:20 PM
For my EFI 2009 Thruxton i had to do a bit of re-jigging inside the headlight to get enough cable out. The other thing i found is that the frame bolts supplied had a different thread to the OEM nuts so had to get some new nuts to get it all hooked up...
06-13-2012, 12:32 PM
Supersport 400 Main Motorcycle: Hat Creek Build#1
flip the ignition backwards to get the most slack
06-25-2012, 09:30 PM
Minitwins Main Motorcycle: Bonneville T100
Posts: 12 Other Motorcycle: Vespa ET4
Ignitition relocation bracket
Hi,
Do you have a picture you can post of this? I am having the same problem, wires not long enough out of the headlight. I have a 2011 t100.
Thanks!
Sean
06-25-2012, 11:06 PM
I did the right hand side mount and had to mount the ignition upside down to fit. No big deal.
Sent from my iPad using MO Free
