Joker Ignition Relocation help... - Page 2 - Triumph Forum: Triumph Rat Motorcycle Forums
Motorcycle.com Classifieds!Motorcycle.com
Old 11-02-2012, 05:01 PM   #11 (permalink)
Main Motorcycle: 2004 Bonneville T100
Originally Posted by TX1911fan View Post
I did the right hand side mount and had to mount the ignition upside down to fit. No big deal.
Sent from my iPad using MO Free
Just received the right side bracket - any stability issues removing the frame bolts? In other words, do I need to brace the bike in any particular way before removing the OEM bolts before installing the new bracket?
Perkology is offline   Reply With Quote
Old 11-02-2012, 07:15 PM   #12 (permalink)
Main Motorcycle: 2006 Blue Thruxton
steventhechef's Avatar
Other Motorcycle: 06 Thruxton - wife's bike
Extra Motorcycle: CB400SF, 4 x DT175, MX80
no and no
steventhechef
Eggs & Bacon. A day's work for a chicken, a lifetime commitment for a pig.
steventhechef is offline   Reply With Quote
Old 11-02-2012, 07:15 PM   #13 (permalink)
Legend
Forchetto's Avatar
No, those lower frame tubes steady things up but nothing will move when you unbolt them.
Old 11-02-2012, 07:22 PM   #14 (permalink)
Thanks guys.
Just to clarify - a rear-wheel stand should be enough? I do not have a lift that will support the whole weight of the bike from underneath the frame.
Old 11-02-2012, 07:27 PM   #15 (permalink)
it doesn't move when you take the bolts out
steventhechef
Old 11-02-2012, 07:30 PM   #16 (permalink)
Fair enough. Thanks again.
Old 11-02-2012, 11:18 PM   #17 (permalink)
Originally Posted by Texascat View Post
I just installed a kit similar to the joker and the cable was not long enough out of the headlight. I had to pull out the connector to get more slack. I tucked in the connector behind the headlight, behind the ear.
Odd enough a friend of mine has a similar set up on his 06, but no issue with the wiring. My is an 07. I guess mine must have had a shorter wire.
I believe the screws will need to be torqued to 45 nm.
Sent from my iPhone using MO Free
Same problem on an 04' T100. Flipped the ignition switch upside down, pulled off the headlight cover and played around with the wiring to give me as much slack as possible, and still not enough. It'll fit, but there's not enough lenth to allow the bars to rotate to the left freely without any pull. Thinking about splicing some extra length in as I'm a little uncomfortabl with idea of removing the connectors from the relative safety of the head lamp housing and placing it behined the ear.
Old 11-02-2012, 11:28 PM   #18 (permalink)
Main Motorcycle: 05 thruxton, 06 scrambler
Other Motorcycle: KTM exc 525
that's just weird. i just put one of these on an '06 scrambler and i had plenty of length on that harness. would they really make that harness in different lengths?...
dwelle is online now   Reply With Quote
Old 11-02-2012, 11:50 PM   #19 (permalink)
I know right!? I've spoken with plenty of people who have done this basic mod with no issues whatsoever. I can't believe it would be cost effective to make the harness in different lengths if it were uneccessary between models, but there is clearly no more lenth to be had out of mine. Oh well.
Old 11-03-2012, 10:44 AM   #20 (permalink)
Main Motorcycle: 2009 Bonnie EFI
TX1911fan's Avatar
I mounted the ignition connectors under the tank because of length issues.
TX1911fan is offline   Reply With Quote
Joker Ignition Relocation Problems gpat Twins Technical Talk 6 12-01-2011 06:01 PM
ignition relocation Scardi The Rocket Science Forum 0 04-20-2007 02:08 PM
ignition relocation.... kidkazi Twins Technical Talk 3 03-31-2007 10:01 AM
Relocation of Ignition switch? Yogi The Rocket Science Forum 6 10-17-2005 11:38 PM
