Innovate A/F gauge vs. LM2 - Page 7 - Triumph Forum: Triumph Rat Motorcycle Forums
SportbikeTrackGear
Old 11-10-2012, 03:49 PM   #61 (permalink)
Main Motorcycle: Bonneville America
grzegorz's Avatar
first start after install!!!!!!!!!!
pictures
grzegorz is online now   Reply With Quote
Old 11-10-2012, 06:51 PM   #62 (permalink)
Main Motorcycle: 2008 Thrux
NorthernThrux's Avatar
Other Motorcycle: 2010 Speed Triple
Looks good. You are a bit lean at idle, but before making any conclusions, you need to calibrate the gauge first and foremost. It showed 22.X in free air and it should say 20.9. The LM-2 allows you to calibrate, and I have to think your gauge does too.
2008 Thrux. 1087 TPUSA motor. SOLD
2010 Speed Triple
NorthernThrux is offline   Reply With Quote
Old 11-10-2012, 07:07 PM   #63 (permalink)
grzegorz's Avatar
its calibrated and on start up shows 22.4 like it should according to manual and this video https://www.youtube.com/watch?v=RKCbU1-IEb4
pictures
Old 11-10-2012, 07:11 PM   #64 (permalink)
Main Motorcycle: 03 T100
mikeinva's Avatar
you have to calibrate with the sensor hanging in the air not in the pipe.
mikeinva is online now   Reply With Quote
Old 11-10-2012, 07:45 PM   #65 (permalink)
grzegorz's Avatar
I did calibrate sensor before bolt on into pipe!!!!!!!!!! I can read manual
pictures
Old 11-10-2012, 08:21 PM   #66 (permalink)
That's bizzarre. My LM-2 manual says 20.9, which is also what I was taught over 30 years ago in a Bosch K-jetronic fuel injection course.
Are you at high altitude ?
EDIT: Never mind. Gdansk is a port city if I remember my history.
2010 Speed Triple
Old 11-10-2012, 09:15 PM   #67 (permalink)
Main Motorcycle: 2004 Bonnie Black Special
PieMan's Avatar
The MTX-L displays 22.4 after calibration, it works differently to the LM-2. The LM-2 dispays the AFR for fresh air after calibration, the MTX-L displays it's upper limit in fresh air which is 22.4.
Mike (UK)
PieMan is offline   Reply With Quote
Old 11-10-2012, 11:26 PM   #68 (permalink)
Aha. Thanks Mike.
2010 Speed Triple
Old 11-11-2012, 04:57 AM   #69 (permalink)
grzegorz's Avatar
I'm not in Gdansk at the moment................unfortunately
pictures
Innovate LM2 for AF tuning nic6020 Twins Technical Talk 24 05-26-2011 02:39 PM
innovate lm2 jed Twins Technical Talk 25 08-01-2010 12:40 PM
Innovate A/F gauge englane Twins Technical Talk 13 07-24-2010 02:08 PM
