09-21-2012, 10:12 PM
#51 (permalink)
Supersport 600 Main Motorcycle: 07 Bonne Black
Location: Mississippi Gulf Coast now Monterey, California
I ordered one off eBay...will be here on Tues. 34.50 shipped. It's about the fastest that I could get one here given the weekend approaching.
That'll give me time to finish my mods with a rear fender chop, and quite possibly, a different tailight.
07 Bonne Black with ARK, AI removed, K&N Pods, Nology Coil and wires, D&D full exhaust, 135 mains/42 pilots, 1 shim @ sea level. Biltwell trackers, Hagon 2810's & progressive fork springs. all blacked out.
09-21-2012, 10:24 PM
#52 (permalink)
SuperSport Main Motorcycle: '06 T100
Posts: 1,370 Other Motorcycle: Kawasaki KXdirtshredder Extra Motorcycle: '76 Tiger 750
Summit's presence on eBay sells them for only around $10+shipping. What was really cool about them is I ordered on Thursday afternoon at 4:45 pm and it was on my doorstep Saturday morning!
Bron-Yr-Aur Garage
09-22-2012, 01:32 AM
#53 (permalink)
Summit's shipping and customer service is second to none, in my experienced opinion.
I ordered the MTXL Thursday, and, lo and behold, in my hands Friday. And price matched, too.
10-21-2012, 11:31 AM
#54 (permalink)
SuperStock Main Motorcycle: Bonneville America
question to you guys wit MTX ....Any problems to read digital display during riding? I'm really fancy that piece of kit.....after my last dissapointing dyno run know that need more work with setting up, this set will pay for itself and can do few other bikes as well
10-21-2012, 01:09 PM
#55 (permalink)
Site Supporter SuperBike Main Motorcycle: Can't decide now!!
Posts: 1,627 Other Motorcycle: Scram + Thrux Extra Motorcycle: '71 BSA Thunderbolt
I have both a permanently installed LC-1/G2 analogue gauge and an MTX-L digital gauge which I've made portable between bikes.
Altho the MTX-L is much easier and straight forward to install, I do find the analogue sweeping needle much easier to monitor the ever-moving A/F reading than I do the digital readout.
During normal riding the A/F is all over the place, due to varying engine load, revs, throttle position etc. etc.
Setting up jetting is a compromise between all these varying results, once you've worked out which ones to totally ignore. I find the analogue gauge much easier to interpret these ever changing readings.
That said tho, the MTX-L is an excellent piece of kit, having used it recently to set up about 6 very different machines, including little 2-stroke engines.
Still one of the most useful tuning tools you can buy.
Works well for me!!
V.
2006 Scrambler, VARK'd, 155/40, 790 In-cam, Pieman'd igniter, DNA Pods, Zard 2:1.
2005 Thruxton, Black now, with ARK, FCR 39's & Uni's, Retimed 790 cams, Barnett clutch and suchlike!!
10-21-2012, 02:04 PM
#56 (permalink)
Thanks for your reply ...... but one more thing here to ask ;this weather now isn't very good to tune the bike or is ok with further adjustment when and if will be warmer ..there is autumn all year round recently here
10-21-2012, 02:28 PM
#57 (permalink)
Ive never experienced any seasonal or elevation issues with jetting here in UK.
Nothing that would warrant changing carb settings anyway.
I dont think the extremes we encounter here would have much effect to be bothered about.
Its all about compromise anyway, dependent on so many other variables.
The variations due to weather conditions would be so minimal as to have little consequence compared to everything else.
All IMHO of course!!
V.
10-21-2012, 04:01 PM
#58 (permalink)
World SuperBike Main Motorcycle: 2008 Thrux
Posts: 1,853 Other Motorcycle: 2010 Speed Triple
I ride from -10C to plus 35C and I do need to make idle adjustments. I try to set everything up for about 15C and then just tweak the fuel screws when it gets cold. You don't want to setup lean at warmer temps, you can get dangerously lean when it cools up.
As a guide. If you set up at 50F, then at 100F you are 6% richer and at 0F you are about 6% leaner than your setup point (according to the JD jetting guide for FCRs). That's about 0.75 AFR units in either direction (i.e. 12.25 to 13.75). So it will make some difference, but if you don't ride in the extremes it isn't a big deal. Pick the midpoint temp of your riding year and set accordingly.
2008 Thrux. 1087 TPUSA motor. SOLD
2010 Speed Triple
10-22-2012, 02:25 AM
#59 (permalink)
Minitwins Main Motorcycle: 2008 Speedmaster EFI
Posts: 15 Other Motorcycle: 125cc Thumpstar
I just installed the innovative gauge on my bike as a permanent install. (used 2 hose clamps and cut up some old tyre tube to mount the gauge. Actually look really nice. lol.
Gauge is running on one cylinder only and the other o2 hole is blocked off.
I plan to use the local drag strip for data logging runs and hook the laptop up in a pannier for logging.With a direct mount to handle bars I find I can read the gauge just fine at full throttle. Very simple to use.
Once I get the data logging component worted (re-route my OBDII plug) then I will let you know how it goes for data logging. So far it works a treat as a constant read gauge.
Only a biker knows why a dog sticks his head out of a car window.
11-03-2012, 05:41 PM
#60 (permalink)
just started my project
bung welded into crossover
and gauge fitted to temporary position
