Oil in my air filter box - Triumph Forum: Triumph Rat Motorcycle Forums
Old 03-08-2012, 12:15 AM   #1 (permalink)
Main Motorcycle: Suzuki
I am working on a friends bike(01 Bonneville), he has not ridden the bike in about 4 months, has tried starting it many times but it wont start...until this weekend(right before bringing to my house) It started but idled/ran very rough and only with choke out.
Could this cranking, not starting then finally kicking over suck some oil up into the filter? I have not checked oil level yet but I will tomorrow.
I plan on removing the carbs, cleaning them/replacing jets, etc.
OR should I be looking for bigger problems?
Thanks, Roger
wfsdno is offline   Reply With Quote
Old 03-08-2012, 12:33 AM   #2 (permalink)
Main Motorcycle: 04 Bonnie black
Probably just an accumulation of blow by oil from the crank case breather hose. Most all Bonnie's do it until the air box is chucked..
rodburner is online now   Reply With Quote
Old 03-08-2012, 12:50 AM   #3 (permalink)
Legend
Forchetto's Avatar
Could be anything from normal blow-by water and oil mist accumulating there and not drained regularly using the tube provided at the bottom of the box, to a worn breather seal. Couple of threads here:
http://www.triumphrat.net/twins-talk...d-air-box.html
http://www.triumphrat.net/twins-tech...e-air-box.html
Old 03-08-2012, 09:00 AM   #4 (permalink)
Thanks! I will check out the links. Hoping for the best!!
Roger
Old 03-09-2012, 04:19 PM   #5 (permalink)
Main Motorcycle: 03 T100
mikeinva's Avatar
being a 01 bike it could have a bad crankcase breather seal.
Old 03-09-2012, 07:03 PM   #6 (permalink)
Mike, can you point me in the direction of the Breather Seal? Where is it located and how easy to replace, just in case this is it.
Thanks, Roger
Old 03-09-2012, 07:46 PM   #7 (permalink)
mikeinva's Avatar
its under the clutch cover in the vent tube it rides on the crank shaft
Old 03-09-2012, 11:59 PM   #8 (permalink)
Legend
Forchetto's Avatar
Seal is shown in post 2 of the second link of my previous post.
More about it on these threads:
http://www.triumphrat.net/twins-tech...-power-12.html
http://www.triumphrat.net/twins-tech...99283-wow.html
Old 03-11-2012, 07:05 PM   #9 (permalink)
Thanks guys - I will start reading and reseaching to figure out the best route to take.
I appreciate all the links! Roger
EFI Bonneville Air Filter and Fuel Filter Sparky Twins Technical Talk 6 02-07-2011 11:58 AM
Oil, filter and air filter questions for '01 S3 lwolniak Speed Triple Forum 5 04-13-2008 01:40 PM
TT600 Oil Filter (Triumph OEM VS. K&N Oil Filter) spin Triumph SuperSports 14 06-11-2007 11:49 PM
New air filter...K&N or BMC? matula Speed Triple Forum 6 05-26-2007 06:10 PM
Fuel Filter/oil filter/oil type Anchorbend Twins Talk 4 07-24-2005 01:00 AM
