Airbox elimination - Triumph Forum: Triumph Rat Motorcycle Forums
Old 02-15-2012, 11:47 AM   #1 (permalink)
Main Motorcycle: 2006 Bonneville 790
VTbonneville's Avatar
Other Motorcycle: Still a lottery ticket...
Airbox elimination
So I am not very experienced with mechanical stuff, but apt enough to figure stuff out and understand, I also have enough hand tools and motivation to be dangerous, so...
Can someone please explain the benefits of airbox elimination? Is there more than just allowing an easier flow of air into the combustion process? What about risk of water getting into the system on long tours without the airbox? How does this affect fuel efficiency/reliability for touring? Seems like airbox elimination is quite popular.
And how is this different from removing some special screw in the fuel line?? Is this specific to EFI motors?
Am I crazy, or would it make the most sense to cluster airbox elimination with new mufflers and carbeuretor tuning/balancing?
Thanks for explaining this, professors.......
VTbonneville is offline   Reply With Quote
Old 02-15-2012, 01:47 PM   #2 (permalink)
Main Motorcycle: 08 Bonneville T100 C/S
wenzel850's Avatar
When you eliminate the airbox and use pod filters, you allow more air into the motor, making more hp, BUT you have to rejet the carbs to take advantage of the increase in air flow. In order to get the most out of it, you also need a free flowing exhaust system. TPUSA has the whole kit, using their Dominator Touring or Sport pipes. The Touring are a lot quieter than the Sports.
Now as for water problems, I've never had a problem. At first I used the outer covers, they robbed power, since I removed them the bike runs stronger. I've never sucked in any water.
Quentin
wenzel850 is offline   Reply With Quote
Old 02-15-2012, 02:01 PM   #3 (permalink)
JAG
Main Motorcycle: 2006 Bonneville T-100
Using the SEARCH function at the top wielded these results...
http://www.triumphrat.net/club-cafe/...n-removal.html
http://www.triumphrat.net/twins-tech...-belmouth.html
http://www.triumphrat.net/for-sale-p...ation-kit.html
http://www.triumphrat.net/twins-tech...-worth-it.html
plus many, many more...
Hope that helps.
JAG is offline   Reply With Quote
Old 02-15-2012, 02:03 PM   #4 (permalink)
Main Motorcycle: 04 Bonneville 904cc
MrTwin's Avatar
Removed the airbox in 2004. It is under my work bench collecting dust.
MrTwin is offline   Reply With Quote
Old 02-15-2012, 04:36 PM   #5 (permalink)
Main Motorcycle: '03 T-100 & '08Tiger1050
Since yours is a 790, you need to be sure whomever you purchase the removal kit from knows you are doing a 790...they also need to know what silencers you will be installing to get in the ballpark on jetting, if you don't purchase the silencers from them. If you keep stock silencers, it would be a waste of time to remove the air box on a 790, IMHO.
The 790 will take bigger main jets than the 865's with no air box and the same open style silencers, so keep in mind when reading what main jets were used to look for the size motor the poster is talking about. From what I have seen, most 865's run somewhere around 145 main jets, and most 790's run around 155 main jets with air box removal and open style silencers...all are a little different, so if you can afford it and have access to someone who does dyno tuning, it is a good idea to get it on the dyno for final tuning, IMHO. Many with 865's run 42 pilot jets, whereas most with 790's run the stock 40 pilot jets. When you have the jetting correct on a 790, it should feel like the front end is coming off the ground when you get around 5000 rpm in 1st or second gears. My MPG increased a little after doing this mod and having the bike tuned on a dyno.
"Am I crazy, or would it make the most sense to cluster air box elimination with new mufflers and carburetor tuning/balancing?"
You are NOT crazy, this is exactly the way to approach this modification, IMHO.
Larry
Old 02-15-2012, 10:19 PM   #6 (permalink)
Main Motorcycle: '07 Black
Easy13's Avatar
+1. And if you haven't removed the AI, do so. Now would be a good time, it doesn't have to coincide with airbox/exhaust/rejet. Your bike will thank you.
P.S. Your bike has no special screws in the fuel line. I think that's an EFI thing.
"Cognito Ergo Wrenchum"
Easy13 is offline   Reply With Quote
Old 02-16-2012, 07:15 AM   #7 (permalink)
Main Motorcycle: Triumph Thruxton EFi
Other Motorcycle: Yamaha R1, Honda CB1000R
Where/what are the "special screws" in the fuel line on EFi?
GDCobra is online now   Reply With Quote
Old 02-16-2012, 09:49 PM   #8 (permalink)
Forgot to mention about riding in the rain...I have ridden all day long in pouring rain with no problems. The cone filters that come with most of the air box removal kits are protected a lot more than the old bikes of the 60's. I rode my ol' 66 BSA Hornet all day in the rain once and didn't have any water problems either, and the carb filters for it were a lot more exposed than the ones on my Bonnie.
Larry
Old 12-04-2012, 04:14 PM   #9 (permalink)
Main Motorcycle: Bonneville T100 EFI
I just want a lllllllittle more confirmation no one's had water lock problems on exposed/water covered intake filters?
Thanks!
iomatic is offline   Reply With Quote
Old 12-04-2012, 08:06 PM   #10 (permalink)
Askari's Avatar
Have a go
The benefits of airbox illimination are that you can run les restrictive filters therefore you can get increased performance.
Most of the pods are treated with oils that stop water ingress as well as dust. I run unis with my side covers on, water is never an issue and i am not super careful with the hose.
When set up well there are no down sides. Reliability is not compromised, fuel consumption need not alter!!!(your right wrist will dictate that).
Well and this is debatable there will be increased noise both intake and exhasut as you need freer flowing exhaust to get the full benefit. This i call a plus!
Like anything it makes sense to do all at once as there will be only 1 set up but obviously $ can dictate.
Things to plan for to save dollars have a plan as to where you are going to go with your mods as duplcation is waste ful.
If you buy pods for your CVK carbs and then change to FCR you will need bigger pods.
Are you going to do your own ARK(airbox removal). You can buy kits but they offer no advantage over a diy. They cost and none that i know of offer as good a mudguard as a OEM cut down.
If you are game have a few tools the airbox mod is simple. The $250 you save can go towards a set of fcr, pipes etc.
Askari is offline   Reply With Quote
Airbox Elimination Kit mrcarb Twins Technical Talk 10 01-14-2011 08:53 PM
Airbox elimination kit .. Which one ? MoToBrIt Club Cafe' 32 11-25-2009 12:16 PM
Which Airbox Elimination Kit do you... yellowrubiu Twins Technical Talk 46 09-19-2009 06:13 PM
Airbox Elimination Kit 5bassman Twins Technical Talk 18 05-28-2008 09:32 PM
Airbox Elimination Kit anybody try it. anglen Twins Technical Talk 11 07-31-2006 06:46 PM
